Can´n edit template in joomla
elviro.valencia
elviro.valencia posted this 2 weeks ago
Good mornig,
In the domain banosdefuensanta.com to through joomla, can´t not acces to the template.
The plugin is installed, the cookies and files temporary also are cleare.
Attached an file whit the detal. Page in blank.
I need enter in the template for modified the design mobil.
I hope your answer.
Thank you. Elviro
Good mornig, In the domain banosdefuensanta.com to through joomla, can´t not acces to the template. The plugin is installed, the cookies and files temporary also are cleare. Attached an file whit the detal. Page in blank. I need enter in the template for modified the design mobil. I hope your answer. Thank you. Elviro
9 Comments
mircot80
Is Solution
mircot80 posted this 2 weeks ago
same exact problem with Joomla 3.9.1
same exact problem with Joomla 3.9.1 !Cattura.JPG!
elviro.valencia
Good morning,
And, what is the solution?
Greetings. Elviro
Good morning, And, what is the solution? Greetings. Elviro
mircot80
I do not know, I hope to receive the answer here.
Please, try applying this fix http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9
Hello, Please, try applying this fix http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 Gina Themler Support
elviro.valencia
Good morning,
I follow yours indications and I solve the problem.
thank you very mush. Elviro
Good morning, I follow yours indications and I solve the problem. thank you very mush. Elviro
mircot80
perfect thanks
perfect thanks
elviro.valencia
Good morning,
I´m updating all the pages of my clients in joomla 3.9.1, in the domain cocimobelsl.es too it has appeared the page in blanck.
But in this case when trying to open the folders to make the modifications, can not open the files.
I hope you help my by solve this.
Thank you. Elviro
Good morning, I´m updating all the pages of my clients in joomla 3.9.1, in the domain cocimobelsl.es too it has appeared the page in blanck. But in this case when trying to open the folders to make the modifications, can not open the files. I hope you help my by solve this. Thank you. Elviro
Elviro,
It is always better to first update the templates (in Themler to the latest version, or at least manually in the files) and only then switch to hiegher CMS version.
Can you access the files via ftp to update them?
Maybe the user you are logged in under doesn't have enough permissions to edit the files directly in Joomla?
If you have the theme saved somewhere, open it in Themler, update to the latest version and simply re-install to Joomla.
Elviro, It is always better to first update the templates (in Themler to the latest version, or at least manually in the files) and only then switch to hiegher CMS version. Can you access the files via ftp to update them? Maybe the user you are logged in under doesn't have enough permissions to edit the files directly in Joomla? If you have the theme saved somewhere, open it in Themler, update to the latest version and simply re-install to Joomla. Gina Themler Support
elviro.valencia
Goog afternoon,
I access to the files through Cpanel and I solve the situation.
Thank yo for you help. Elviro
Goog afternoon, I access to the files through Cpanel and I solve the situation. Thank yo for you help. Elviro
