Woocommerce Product Gallery with Lightbox
walter.gasslbauer
walter.gasslbauer posted this 28 January 2019
https://www.wohlmannstetter.de/produkt/deutz-fahr-agrotron-6-00/
Hello.
Is it possible to open the Woocomerce product-gallery with lightbox?
When I klick on the pictures in the product bellow, only the linke is opened without Lightbox-Effect.
https://www.wohlmannstetter.de/produkt/deutz-fahr-agrotron-6-00/ Hello. Is it possible to open the Woocomerce product-gallery with lightbox? When I klick on the pictures in the product bellow, only the linke is opened without Lightbox-Effect.
info1938
info1938 posted this 15 February 2019
We do have the same problem.
Our product image doesn't have a lightbox effect either.
Themler, we need some support here.
We do have the same problem. Our product image doesn't have a lightbox effect either. Themler, we need some support here.
copywriter
copywriter posted this 14 May 2019
I found a solution to install this plugin: . https://cs.wordpress.org/plugins/responsive-lightbox/.
After installing it in the plugin settings, enable WooCommerce Lightbox (and the ideal lightbox is prettyPhoto or FancyBox). Woocommerce product image previews are then displayed in the lightbox.
I found a solution to install this plugin: . https://cs.wordpress.org/plugins/responsive-lightbox/. After installing it in the plugin settings, enable WooCommerce Lightbox (and the ideal lightbox is prettyPhoto or FancyBox). Woocommerce product image previews are then displayed in the lightbox.
