favicon URL
hotfaucet
hotfaucet posted this 28 January 2019
Where is the favicon URL hiding? When I publish a template with a favicon using a URL, Themler decides to insert code making the favicon "disappear". It should be and is
link href="/url(https:// etc... )" etc.
why is this happening? how can i fix this? is there something hard coded that i can alter to fix this?
Where is the favicon URL hiding? When I publish a template with a favicon using a URL, Themler decides to insert code making the favicon "disappear". It should be and is `link href="/url(https:// etc... )"` etc. why is this happening? how can i fix this? is there something hard coded that i can alter to fix this?
Support Team posted this 29 January 2019
Please try adding a full path, not relative path. Does the same issue happen?
Hello, Please try adding a full path, not relative path. Does the same issue happen? Sincerely, Nettie
hotfaucet
hotfaucet posted this 29 January 2019
Yes, I'm including the full path.
hotfaucet
hotfaucet posted this 30 January 2019
I don't know why the same sentence kept repeating in my initial question. I certainly didn't type it that many times :D
Support Team posted this 30 January 2019
I have edited your initial post and wrapped the path into code. Could you please provide the full URL that you use to insert the favicon so that we test it on our end? Please make sure to wrap it into code as well.
Hello, I have edited your initial post and wrapped the path into `code`. Could you please provide the full URL that you use to insert the favicon so that we test it on our end? Please make sure to wrap it into code as well. Sincerely, Nettie
