when i make a Artisteer import I get the message File does not exist
paaspop
paaspop posted this 4 weeks ago
JInstaller: :Install:File does not exist C:\ Programdata\Themler\hd_data\themler_35727126\joomla\templates\unzitled2\editor\themes\Neujahrstauchen\field Error installing template
File doen not exist but why?
JInstaller: :Install:File does not exist C:\ Programdata\Themler\hd_data\themler_35727126\joomla\templates\unzitled2\editor\themes\Neujahrstauchen\field Error installing template File doen not exist but why?
15 Comments
Please make sure you have exported the project as Themler theme using this Artisteer version:
Let us know if the issue is still present.
Hello, Please make sure you have exported the project as Themler theme using this Artisteer version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Let us know if the issue is still present. Sincerely, Nettie
paaspop
Yes I did but maybe the problem is that I have a old expired Artisteer License
We have extended your existing license to January 28, 2020. Please try to activate Artisteer now.
Hello, We have extended your existing license to January 28, 2020. Please try to activate Artisteer now. Sincerely, Nettie
paaspop
On Artisteer I get the Message "Verbindung mit aktivierubngsservice unmöglich" what means activation with the activationservice not possible. I deactivated the firewall but I get still the message.
I have just tried it now with my Artisteer installation, and activation is successful. Could you please try to temporarily disable also antivirus, VPN and/or any other third-party software that may block connection?
Hello, I have just tried it now with my Artisteer installation, and activation is successful. Could you please try to temporarily disable also antivirus, VPN and/or any other third-party software that may block connection? Sincerely, Nettie
paaspop
Hi Nettie
Ok, now activation is succesful, but with the Import to Themler i have still the same failure.
I dont have a ordner in C:\ProgramData\Themler\hd_data\themler_35727126\joomla\templates\untitled\editor\themes
regards
Alex
Hi Nettie Ok, now activation is succesful, but with the Import to Themler i have still the same failure. I dont have a ordner in C:\ProgramData\Themler\hd_data\themler_35727126\joomla\templates\untitled\editor\themes regards Alex
paaspop
attached the .zip file
I can reproduce the issue with the attached .zip. Could you please attach the initial .artx project for investigation?
Hello, I can reproduce the issue with the attached .zip. Could you please attach the initial .artx project for investigation? Sincerely, Nettie
paaspop
Hello Nettie,
attached der .artx file.
Kind regards,
Alex
Hello Nettie, attached der .artx file. Kind regards, Alex
Hello Alex,
Sorry but could you please pur the .artx into a folder, zip it and then attach, as at the moment I cannot download the attached file most probably because of the format.
Hello Alex, Sorry but could you please pur the .artx into a folder, zip it and then attach, as at the moment I cannot download the attached file most probably because of the format. Sincerely, Nettie
paaspop
Hi Nettie,
attached the .Artx file into a zip.
Alex
Hi Nettie, attached the .Artx file into a zip. regards, Alex
paaspop
paaspop posted this 3 weeks ago
any news?
any news?
I could successfully export the theme from Artisteer and import it in Themler. Please find the theme attached and try to import it on your end. Please let us know the result.
Hello, I could successfully export the theme from Artisteer and import it in Themler. Please find the theme attached and try to import it on your end. Please let us know the result. Sincerely, Nettie
paaspop
Hello Nettie
Now I can import the theme into Themler, Thanks. Is there something wrong with my Artisteer export function?
I have more Artisteer templates which are not working.
Alex
Hello Nettie Now I can import the theme into Themler, Thanks. Is there something wrong with my Artisteer export function? I have more Artisteer templates which are not working. Regards, Alex
Please make sure you export the theme in the correct way: in the Export tab select Themler option and then in the dialog screen select Joomla.
Hello, Please make sure you export the theme in the correct way: in the Export tab select Themler option and then in the dialog screen select Joomla. Sincerely, Nettie
