Software bug
svl1988
svl1988 posted this 29 January 2019
First of all, the software looks great and powerfull. But after I saved my first template and I make a new template, I lost the first one...
The template still excist, but the first template is the same as the new version. So I lost al components :(
First of all, the software looks great and powerfull. But after I saved my first template and I make a new template, I lost the first one... The template still excist, but the first template is the same as the new version. So I lost al components :(
6 Comments
Support Team posted this 29 January 2019
Could you please specify how the issue has happened? Have you created a theme with Themler desktop? Was the second template created from the default template or from the first one?
Hello, Could you please specify how the issue has happened? Have you created a theme with Themler desktop? Was the second template created from the default template or from the first one? Sincerely, Nettie
svl1988
I use the Themler desktop version. After I save the template, I click on new. A copy of the saved template opens. When I save the second template by another name he overwrite also the first template. I don't know how to start a new template, there is no other button then "new template".
Is it possibly content that you have changed so far and not design? Content will be displayed the same for all created themes in Themler desktop, as there is a single CMS installation and sample content (posts, pages) in it.
Hello, Is it possibly content that you have changed so far and not design? Content will be displayed the same for all created themes in Themler desktop, as there is a single CMS installation and sample content (posts, pages) in it. Sincerely, Nettie
svl1988
So, if I onderstand correctly it is only posible to make one template at all? I have several personal projects where I make more than one template.
Or is there another way to safe projects without loosing created themes? The only thing wat Themler saved is the header and footer, all other blocks and widget areas are empty. So every time I open a saved templete there is only the header and footer displayed.
So, if I onderstand correctly it is only posible to make one template at all? I have several personal projects where I make more than one template. Or is there another way to safe projects without loosing created themes? The only thing wat Themler saved is the header and footer, all other blocks and widget areas are empty. So every time I open a saved templete there is only the header and footer displayed.
wpexpertinbd
wpexpertinbd posted this 01 February 2019
Hello svl1988,
Themler desktop working with a local cms site like WordPress or Joomla or others & there have only one installation for specific cms. Now if you make a theme with themler that means there have header, footer, menu, page & post e.t.c. So, all are theme related. So what you need to do if you want to make a new theme. First export your present theme with content or without content, also you can export with themler editing option or without themler editing option. Now, after exporting your old theme, you can use it as per your exported option.
So, you can again start a new theme & follow the same step. It's not like artisteer because artisteer does not have cms option but themler have live cms option. Like you can use themler into your live WordPress or Joomla or others cms, but you are not able to install artisteer with any cms.
Hello svl1988, Themler desktop working with a local cms site like WordPress or Joomla or others & there have only one installation for specific cms. Now if you make a theme with themler that means there have header, footer, menu, page & post e.t.c. So, all are theme related. So what you need to do if you want to make a new theme. First export your present theme with content or without content, also you can export with themler editing option or without themler editing option. Now, after exporting your old theme, you can use it as per your exported option. So, you can again start a new theme & follow the same step. It's not like artisteer because artisteer does not have cms option but themler have live cms option. Like you can use themler into your live WordPress or Joomla or others cms, but you are not able to install artisteer with any cms.
Support Team posted this 02 February 2019
Also, answering your question:
at all?
No, you may create as many themes as you need.
We would like to add that if you need to create several themes and content for them, you may consider installing Themler themes on a localhost and edit different content for different websites, and export them later to be installed on a live site. Let us know if any additional questions appear.
Hello, Also, answering your question: > So, if I onderstand correctly it is only posible to make one template > at all? No, you may create as many themes as you need. We would like to add that if you need to create several themes and content for them, you may consider installing Themler themes on a localhost and edit different content for different websites, and export them later to be installed on a live site. Let us know if any additional questions appear. Sincerely, Nettie
