Warning: Unable to insert the following controls: "Logo, HMenu"
partitionman
partitionman posted this 06 February 2019
Dear Support-Team,
after i have pressed the button: "Suggest Homepage", the generator creates new suggestion and finaly shows following warning: Unable to insert the following controls: "Logo, HMenu"
Furthmore no logo or header contend is showed.
I have tested on Windows and Mac to create an Joomla template.
In both tries the failure coccures.
Could you please help me here?
Best regards,
Partitionman
Dear Support-Team, after i have pressed the button: "Suggest Homepage", the generator creates new suggestion and finaly shows following warning: Unable to insert the following controls: "Logo, HMenu" Furthmore no logo or header contend is showed. I have tested on Windows and Mac to create an Joomla template. In both tries the failure coccures. Could you please help me here? Best regards, Partitionman
Support Team posted this 06 February 2019
Please try to update the default Themler for Joomla theme to the latest Themler version and save it. Then re-open it and try to Suggest Homepage. Let us know if the issue is still present.
Hello, Please try to update the default Themler for Joomla theme to the latest Themler version and save it. Then re-open it and try to Suggest Homepage. Let us know if the issue is still present. Sincerely, Nettie
chinas
chinas posted this 19 April 2019
I have the same problem. Your recommendations did not help me.
Support Team posted this 19 April 2019
Does the issue happen when you try to create a new theme or with the existing one?
Hello, Does the issue happen when you try to create a new theme or with the existing one? Sincerely, Nettie
chinas
I'm trying to create a new template in the latest version of the application.
Please fix the problem as soon as possible. I have an urgent order from the customer. It is for this reason that I acquired a license.
Hello, I'm trying to create a new template in the latest version of the application. Please fix the problem as soon as possible. I have an urgent order from the customer. It is for this reason that I acquired a license.
chinas
chinas posted this 20 April 2019
I do not know what you have done, but after the next launch of the program, the problem disappeared.
