we have a small issue, when we fill sending form (we use Form2Contnet joomla component) and miss some required field/s system not turn error message, just do noting(page stay)When everything is ok return message for successfully completed....
We connect with developer and hi tell as to try this with Protostar, default joomla template, it work fine. When we switch themler theme warning no work. Message for successfully completed uploading working, only warning message not appear
we have a small issue, when we fill sending form (we use Form2Contnet joomla component) and miss some required field/s system not turn error message, just do noting(page stay)When everything is ok return message for successfully completed.... We connect with developer and hi tell as to try this with Protostar, default joomla template, it work fine. When we switch themler theme warning no work. Message for successfully completed uploading working, only warning message not appear
