How to make a half of page static?
vitalii.reznic
vitalii.reznic posted this 24 February 2019
How could I realize a ideea as on image. Divide the page in two columns and make the left part static (also it must occupy the whole column).
Images are attached
How could I realize a ideea as on image. Divide the page in two columns and make the left part static (also it must occupy the whole column). Images are attached
Support Team posted this 25 February 2019
As a possible solution, you may put Columns into the Content&Sidebars area. Then drag-and-drop Posts into the second column and add a section or another static controls into the first column.
Hello, As a possible solution, you may put Columns into the Content&Sidebars area. Then drag-and-drop Posts into the second column and add a section or another static controls into the first column. Sincerely, Nettie
