Remove Schema
rkuiper
rkuiper posted this 26 February 2019
Is there a way to remove the schema from the templates?
Any help is appreciated.
Hi, Is there a way to remove the schema from the templates? Any help is appreciated. Thanks
6 Comments
Support Team posted this 26 February 2019
Please, specify what schema you mean exactly.
Hello, Please, specify what schema you mean exactly. Gina Themler Support
rkuiper
Hi Gina,
Basically any schema, but mainly right now the schema for article for the page template.
Rogier
Hi Gina, Basically any schema, but mainly right now the schema for article for the page template. Thanks, Rogier
admin34
admin34 posted this 27 February 2019
I asked a question over 2 weeks ago and have not recived a responce this is the question http://answers.themler.io/questions/183608/changing-files-directly-on-my-cpanel
Support Team posted this 28 February 2019
You can remove almost any element in the layout from the panel on the left:
If you mean something else, please, provide a screenshot.
You can remove almost any element in the layout from the panel on the left: !Screenshot-1.png! If you mean something else, please, provide a screenshot. Gina Themler Support
rkuiper
rkuiper posted this 07 March 2019
Hi Gina,
I understand that. What i need is to remove the structured data (schema). from the templates.
As you can see in the screenshot, its incorrect schema. Every page is using the "article" This is only true for a blog article. Not for other static pages.
Rogier
Hi Gina, I understand that. What i need is to remove the structured data (schema). from the templates. As you can see in the screenshot, its incorrect schema. Every page is using the "article" This is only true for a blog article. Not for other static pages. Thanks, Rogier
Support Team posted this 14 March 2019
It is not possible to remove that in Themler itself.
Do you use Joomla? If so, you may find this code in the php file directly under Templates -> styles , see the path on the screenshot:
It is not possible to remove that in Themler itself. Do you use Joomla? If so, you may find this code in the php file directly under Templates -> styles , see the path on the screenshot: !schema.png! Gina Themler Support
