STICKY MENU AND STICKY SECTION
AndreaPollini
AndreaPollini posted this 2 weeks ago
I need to set the double menu with sticky, but not in the same section.
The first menu is in the header(the general menu) and a second menu in the template, because it change with the pages.
I set sticky extension to the both,
but when I scroll through the page only one of the 2 remains visible.
I also tried to set an offset in px in the second menu and initially seemed to work but when I open the first menu (mobile example) overlap.
Is it possible to fix the sticky extension not to the screen but to the menu above or section above?
/Andrea
Hi, I need to set the double menu with sticky, but not in the same section. The first menu is in the header(the general menu) and a second menu in the template, because it change with the pages. I set sticky extension to the both, but when I scroll through the page only one of the 2 remains visible. I also tried to set an offset in px in the second menu and initially seemed to work but when I open the first menu (mobile example) overlap. Is it possible to fix the sticky extension not to the screen but to the menu above or section above? Regards /Andrea
Hello Andrea,
Could you please provide the link to your site where we can see those two menus?
Hello Andrea, Could you please provide the link to your site where we can see those two menus? Gina Themler Support
