Text in the text box
admin34
admin34 posted this 2 weeks ago
All the words in the text box are underlined, but only when viewed on a mobile phone. I have not used the option to underline any word in the text box. I have looked in the html option on themler and there is no code in there at all. I have deleted the text box and pasted the text back in as text only, all the things that I have tried above didn't work. The website address is below.
https://www.nambourelc.com.au/
All the words in the text box are underlined, but only when viewed on a mobile phone. I have not used the option to underline any word in the text box. I have looked in the html option on themler and there is no code in there at all. I have deleted the text box and pasted the text back in as text only, all the things that I have tried above didn't work. The website address is below. https://www.nambourelc.com.au/
Hello Allan,
I can see the underline set under Section in the code. You can try switching to mobile view in Themler and check all Text settings under this Section.
If you can't find any underline there, you can add this code to Home -> Settings -> Additional CSS:
.bd-section-7 {
    text-decoration: none!important;
Hello Allan, I can see the underline set under Section in the code. You can try switching to mobile view in Themler and check all Text settings under this Section. If you can't find any underline there, you can add this code to Home -> Settings -> Additional CSS: .bd-section-7 { text-decoration: none!important; } Gina Themler Support
admin34
HI Gina,
Thanks for the CSS fix, that worked. I hope to hear from support about my other problem soon, see the link below. https://answers.themler.io/questions/184608/changing-files-directly-on-my-cpanel
HI Gina, Thanks for the CSS fix, that worked. I hope to hear from support about my other problem soon, see the link below. https://answers.themler.io/questions/184608/changing-files-directly-on-my-cpanel
Answered
Answered Gina
admin34
