Location of objects in the header. Preview on the phone
mariusz20
mariusz20 posted this 1 weeks ago
I have a problem with the correct placement of objects contained in the page header. I used for this purpose one of the finished projects attached to Themler. Without any modifications the header on the phone is displayed correctly, but just move the search engine widget or menu to a different place and the objects are overlapping (image1) on the phone. I'm not talking about the situation anymore when I add another object (image2).
Can someone explain to me how to determine the location of individual objects so that they display properly on the phone?
greetings
Mariusz
Hello, I have a problem with the correct placement of objects contained in the page header. I used for this purpose one of the finished projects attached to Themler. Without any modifications the header on the phone is displayed correctly, but just move the search engine widget or menu to a different place and the objects are overlapping (image1) on the phone. I'm not talking about the situation anymore when I add another object (image2). Can someone explain to me how to determine the location of individual objects so that they display properly on the phone? greetings Mariusz
Hello Mariusz,
I apologize for the delay.
Try switching to OUTLINE tab on the left panel in Themler, there you would see if the object are located in the same container, section, column. You would probably need to make sure they are in a separate container to prevent overlapping. Also you can check the position of the object. Right click on each -> go to More Options and check margins and position defined for the object in the panel that appears on the right.
If you need more specific help, please, create new Private ticket with temporary credentials to your site.
Hello Mariusz, I apologize for the delay. Try switching to OUTLINE tab on the left panel in Themler, there you would see if the object are located in the same container, section, column. You would probably need to make sure they are in a separate container to prevent overlapping. Also you can check the position of the object. Right click on each -> go to More Options and check margins and position defined for the object in the panel that appears on the right. If you need more specific help, please, create new Private ticket with temporary credentials to your site. Gina Themler Support
