Wordpress comments pagination ?
Stagger Lee posted this 07 August 2015
I dont see this function. Artisteer has it.
12 Comments
To explain better, I am using one simple page as Guestbook. Without pagination I can delete it.
Support Team posted this 10 August 2015
Hello Stagger Lee,
I'll add this suggestion to our wish list.
Hello Stagger Lee, I'll add this suggestion to our wish list. regards, Aileen
Support Team posted this 12 August 2015
Just a follow up: as usually create Wish type topic here on forum to let other THemler users vote for this feature.
Just a follow up: as usually create Wish type topic here on forum to let other THemler users vote for this feature. regards, Aileen
Stagger Lee posted this 12 August 2015
Can you please change status of topic ?
I was not sure if this option is hidden somewhere.
Can you please change status of topic ? I was not sure if this option is hidden somewhere.
Support Team posted this 13 August 2015
Done :)
Done :)
Stagger Lee posted this 13 August 2015
Thank you.
Somehow I dont think it should be decided by votes. All modern comments functions NEED pagination. It is in your interese people dont complain about slow Themler themes.
Each comment in WordPress is a "Post". Imagine what it does to database and server when it needs to query 200-300 hundreds of comments on one Post. And if visitors read news, new posts, database has to do this work for each viewed Post.
OK, not all websites has so many comments, and so many visitors clicking at the same time. But better you prevent it and sleep well.
Thank you. Somehow I dont think it should be decided by votes. All modern comments functions NEED pagination. It is in your interese people dont complain about slow Themler themes. Each comment in WordPress is a "Post". Imagine what it does to database and server when it needs to query 200-300 hundreds of comments on one Post. And if visitors read news, new posts, database has to do this work for each viewed Post. OK, not all websites has so many comments, and so many visitors clicking at the same time. But better you prevent it and sleep well.
Support Team posted this 15 August 2015
Hello Stagger Lee,
I see your point.
I discussed your request with our team and the result is : Let Themler users vote for it as for any other feature.
We've already implemented features by users request and we're monitoring the wish list.
Hello Stagger Lee, I see your point. I discussed your request with our team and the result is : Let Themler users vote for it as for any other feature. We've already implemented features by users request and we're monitoring the wish list. Regards, Aileen
Stagger Lee posted this 15 August 2015
OK.
Ask them if they have some handy code snippet for CMS Code block, for pagination. If this is possible.
OK. Ask them if they have some handy code snippet for CMS Code block, for pagination. If this is possible.
Support Team posted this 17 August 2015
Hello Stagger Lee,
I'm sorry but we do not have a solution/workaround right now.
Hello Stagger Lee, I'm sorry but we do not have a solution/workaround right now. regards, Aileen
Stagger Lee posted this 20 December 2015
This plugin still works for long comments list pagination. Just give us option to insert CMS code control right after comments list (and right before). Now we can insert it, but all comments in list get pagination beneath. If we take first available space for CMS block it ends outside comments loop and shows nothing. I mean somewhere where ordinary Themler pagination is.
https://wordpress.org/plugins/wp-pagenavi/
I tried manually in comment template and it works fine.
This plugin still works for long comments list pagination. Just give us option to insert CMS code control right after comments list (and right before). Now we can insert it, but all comments in list get pagination beneath. If we take first available space for CMS block it ends outside comments loop and shows nothing. I mean somewhere where ordinary Themler pagination is. https://wordpress.org/plugins/wp-pagenavi/ I tried manually in comment template and it works fine.
Sorry, this is right plugin:
https://wordpress.org/plugins/wp-paginate/
Sorry, this is right plugin: https://wordpress.org/plugins/wp-paginate/
Even this simple snippet from WP codex works, just we had a right place to insert CMS code block:
<?php paginate_comments_links();=""?>
Even this simple snippet from WP codex works, just we had a right place to insert CMS code block: <?php paginate_comments_links();=""?>
