Export
okosoko
okosoko posted this 29 March 2019
Themler isn't exporting files right. When i click export and include content, it doesn't ask me which folder on my system i want to export to. It export somewhere and goes blank.
I have searched my entire system for the file name but couldn't find the export.
Themler isn't exporting files right. When i click export and include content, it doesn't ask me which folder on my system i want to export to. It export somewhere and goes blank. I have searched my entire system for the file name but couldn't find the export.
15 Comments
Support Team posted this 29 March 2019
Do you have Themler for Mac? If so, please try to look for the file at the default save location for Safari browser or on the Desktop. If you still cannot locate the file, please try to open Themler through a browser using a link like this
http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/
The exact numbers are visible in Themler Live Preview.
Try different browsers like Safari, Firefox, Chrome and to export.
As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website.
Hello, Do you have Themler for Mac? If so, please try to look for the file at the default save location for Safari browser or on the Desktop. If you still cannot locate the file, please try to open Themler through a browser using a link like this http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ The exact numbers are visible in Themler Live Preview. Try different browsers like Safari, Firefox, Chrome and to export. As a temporary solution, you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type `~/Library` and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website. Sincerely, Nettie
okosoko
I did that, saw wordpress but can't find the theme i created.
Why can't the export be easy like artisteer and nicepage.
I bought this software in 2015, stopped using it.
I just bought this software again yesterday and have found 3 bugs already.
First the application tells me sever timeout, i had to force quit several times to get it working again.
Secondly, the application hangs for no reason. I also have to force quit to get it working.
Now the export isn't working.
I did that, saw wordpress but can't find the theme i created. Why can't the export be easy like artisteer and nicepage. I bought this software in 2015, stopped using it. I just bought this software again yesterday and have found 3 bugs already. First the application tells me sever timeout, i had to force quit several times to get it working again. Secondly, the application hangs for no reason. I also have to force quit to get it working. Now the export isn't working.
Support Team posted this 30 March 2019
As a rule, export should work. But in some cases the issue with export can happen on Mac, and we cannot reproduce it to fix it, so it looks to depend on some specific conditions in the system.
Do you mean that you couldn't find the theme after having Themler opened in a browser or by manually accessing the Library?
Hello, As a rule, export should work. But in some cases the issue with export can happen on Mac, and we cannot reproduce it to fix it, so it looks to depend on some specific conditions in the system. Do you mean that you couldn't find the theme after having Themler opened in a browser or by manually accessing the Library? Sincerely, Nettie
okosoko
okosoko posted this 30 March 2019
I see it in the browser when i do PREVIEW. but cannot access it in library following the steps, neither can i find the file name of the theme.
Support Team posted this 01 April 2019
Please try the following:
1. Start Themler.
2. Open this URL in a browser:
http://127.0.0.1:29958/themler_2000075927/startup/
What happens after this?
Hello, Please try the following: 1. Start Themler. 2. Open this URL in a browser: http://127.0.0.1:29958/themler_2000075927/startup/ What happens after this? Sincerely, Nettie
okosoko
okosoko posted this 14 April 2019
I'm still unable to export and i don't think it makes any sense to buy a program that won't work for me.
Support Team posted this 15 April 2019
What exactly happens when you try to open Themler in a browser? Does it open at all?
Hello, What exactly happens when you try to open Themler in a browser? Does it open at all? Sincerely, Nettie
okosoko
okosoko posted this 23 April 2019
It opens but I'm not trying to export through a browser and then while creating a design, it keeps hanging.
Why can't there just be file - export?
It opens but I'm not trying to export through a browser and then while creating a design, it keeps hanging. Why can't there just be file - export?
Support Team posted this 25 April 2019
Hello Tosin,
I apologize for the delay.
Could you please try to export now?Does the problem still orccurs?
Hello Tosin, I apologize for the delay. Could you please try to export now?Does the problem still orccurs? Gina Themler Support
okosoko
okosoko posted this 05 May 2019
ok, I will try it now to see.
okosoko
It still occurs.
Export as a zip file with contents still doesn't work also.
It still occurs. Export as a zip file with contents still doesn't work also.
Support Team posted this 06 May 2019
Do you mean that when you try to open Themler in a browser and use the same File >> Export, it is not successful either?
Hello, Do you mean that when you try to open Themler in a browser and use the same File >> Export, it is not successful either? Sincerely, Nettie
okosoko
okosoko posted this 07 May 2019
You mean i have to open my themler design on a web browser and the go back to the software to do file >> Export.
Will try that tonight.
You mean i have to open my themler design on a web browser and the go back to the software to do file >> Export. Will try that tonight.
okosoko
okosoko posted this 08 May 2019
I tried it this way, it didn’t work.
Should I uninstall and reinstall the software.
I tried it this way, it didn’t work. Should I uninstall and reinstall the software.
Support Team posted this 08 May 2019
Could you please try using Firefox and let us know if it works then?
Could you please try using Firefox and let us know if it works then? Gina Themler Support
