Blocks in Widget Areas
peter.james2
peter.james2 posted this 07 August 2015
How do I format blocks (widgets) that go in sidebars (widget areas) in WordPress. In Artisteer I did this through Blocks but I can't see how to do it in Themler.
Many thanks...Peter
How do I format blocks (widgets) that go in sidebars (widget areas) in WordPress. In Artisteer I did this through Blocks but I can't see how to do it in Themler. Many thanks...Peter
shaulhadar
shaulhadar posted this 07 August 2015
Hi Peter, what do you mean in format?
if you mean adding a widget area, its in the insert tab, under "widget area". i added you an image to see what i mean.
if you need to style the widget area, just press on it, and than you can style it and change it's name or whatever you need to do..
Hi Peter, what do you mean in format? if you mean adding a widget area, its in the insert tab, under "widget area". i added you an image to see what i mean. if you need to style the widget area, just press on it, and than you can style it and change it's name or whatever you need to do..
peter.james2
peter.james2 posted this 08 August 2015
What I mean is styling the widgets themselves rather than the whole area. For example having borders and backgrounds.
shaulhadar
shaulhadar posted this 08 August 2015
So, all you need to do is press once on the widget area, and than all the styling options will be on the left side.
I attached an image so you can see what I mean...
So, all you need to do is press once on the widget area, and than all the styling options will be on the left side. I attached an image so you can see what I mean...
