Articles Doubled
DaveOzric
DaveOzric posted this 1 weeks ago
Hello, I constantly have this issue on my home template. I just want to use a single article menu item on the homepage. However I get the article 2x times on the page and cannot remove the one that is not where it's supposed to be.
What is the solution to this?
Hello, I constantly have this issue on my home template. I just want to use a single article menu item on the homepage. However I get the article 2x times on the page and cannot remove the one that is not where it's supposed to be. What is the solution to this? Thank you !firefox-2019-04-12-13-13-47.png! !firefox-2019-04-12-13-14-05.png!
Hello Dave,
Try switching CMS Control off, save, then turn it back on. Sometimes it helps.
If it doesn't, let us know, we will move this topic to private and check your theme.
Hello Dave, Try switching CMS Control off, save, then turn it back on. Sometimes it helps. If it doesn't, let us know, we will move this topic to private and check your theme. Gina Themler Support
DaveOzric
Is Solution
DaveOzric posted this 5 days ago
I was able to eventually find a way to remove it. Not 100% sure what I did. At some point there was a second CMS Content element on the left side bar I and I deleted it.
I was able to eventually find a way to remove it. Not 100% sure what I did. At some point there was a second CMS Content element on the left side bar I and I deleted it. Thanks
Support Team posted this 4 days ago
Thank you for letting us know.
Thank you for letting us know. Gina
