Fatal error: Allowed memory size
Kevin Doussaint
Kevin Doussaint posted this 20 April 2019
Since last Woocommerce Update all my Themler websites are broken on the cart page with this error :
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16384 bytes) in /home/www/babiolesetbricoles/wp-content/themes/MYTHEME/woocommerce/cart/cart-totals-wrapper.php on line 5
I tried to allocate more memory on php.ini or wp-config.php but did not solved the problem wich seems deeper. When I change my theme it solve the problem (wich is not present on my other themes like elementor etc...).
Could you please help me ?
Best regards
Kevin
Hi, Since last Woocommerce Update all my Themler websites are broken on the cart page with this error : Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16384 bytes) in /home/www/babiolesetbricoles/wp-content/themes/MYTHEME/woocommerce/cart/cart-totals-wrapper.php on line 5 I tried to allocate more memory on php.ini or wp-config.php but did not solved the problem wich seems deeper. When I change my theme it solve the problem (wich is not present on my other themes like elementor etc...). Could you please help me ? Best regards Kevin
17 Comments
Kevin Doussaint
More informations :
My server limit is 256M
And I got this report :
babiolesbricoles03/woocommerce/archive-product.php version 3.3.0 est obsolète. La version du noyau est 3.4.0,
babiolesbricoles03/woocommerce/cart/cart.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/error.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/notice.php version 1.6.4 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/success.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
More informations : My server limit is 256M And I got this report : babiolesbricoles03/woocommerce/archive-product.php version 3.3.0 est obsolète. La version du noyau est 3.4.0, babiolesbricoles03/woocommerce/cart/cart.php version 3.3.0 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/error.php version 3.3.0 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/notice.php version 1.6.4 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/success.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
GuPatrolOh3
GuPatrolOh3 posted this 5 weeks ago
Same.
Same.
Kevin Doussaint
Kevin Doussaint posted this 4 weeks ago
This delay of answer is just insane ! Hopefully I make backups before every update ...
Themler team, please don't let your customers on this way, we cannot updates our woocommerce websites, models are outdated from a long time, and now does not work anymore :(
This delay of answer is just insane ! Hopefully I make backups before every update ... Themler team, please don't let your customers on this way, we cannot updates our woocommerce websites, models are outdated from a long time, and now does not work anymore :(
Almiab
Almiab posted this 4 weeks ago
The same is on our pages. Request for urgent solution !!
Administración web
Administración web posted this 4 weeks ago
También tengo el mismo problema, precisamente hace como minutos que realicé una nueva instalación.
Esperemos reparen lo antes posible.
También tengo el mismo problema, precisamente hace como minutos que realicé una nueva instalación. Esperemos reparen lo antes posible.
lisichka17
lisichka17 posted this 4 weeks ago
Y yo también. Es problema del "THEMLER" y bastante hace tiempo. Y todavia no hay ni un solucion del equipo "THEMLER". Por favor solucionara por fin!!!!!!
> También tengo el mismo problema, precisamente hace como minutos que realicé una nueva instalación. > Esperemos reparen lo antes posible. Y yo también. Es problema del "THEMLER" y bastante hace tiempo. Y todavia no hay ni un solucion del equipo "THEMLER". Por favor solucionara por fin!!!!!!
lisichka17
After updating the plugin woocommerce to version 3.6.1. The page with cart comes out with an error:
"Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 32768 bytes) in
/home/nataluw309/domains/studioexpertlash.com/public_html/wp-content/themes/Expert002_preview/woocommerce/cart/cart-totals-wrapper.php on line 1"
The problem can be solved if the internal templates of the "THEMLER" are updated.
Marked in red:
enter image description here
This problem has long existed and now it is time to solve it.
Do it please!!!
After updating the plugin woocommerce to version 3.6.1. The page with cart comes out with an error: **"Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 32768 bytes) in /home/nataluw309/domains/studioexpertlash.com/public_html/wp-content/themes/Expert002_preview/woocommerce/cart/cart-totals-wrapper.php on line 1"** The problem can be solved if the internal templates of the "THEMLER" are updated. Marked in red: ![enter image description here][1] **This problem has long existed** and now it is time to solve it. Do it please!!! [1]: http://studioexpertlash.com/images1/66.png
Could you please try updating the theme to Themler version 481?
Could you please try updating the theme to Themler version 481? Gina Themler Support
Albin Klein
Albin Klein posted this 4 days ago
SOLVED! Thanks, I was breaking my head...
WebCreativa.cl
WebCreativa.cl posted this 4 days ago
Where do I download the 481 ?, just download until the 475
Could you please try updating the theme to Themler version 481? Where do I download the 481 ?, just download until the 475
Support Team posted this 3 days ago
481 was a beta release. Enable beta updates in your profile on themler.io site (log in to the site, go to Profile and check the option to get beta updates, reload themler and the theme should offer the update).
481 was a beta release. Enable beta updates in your profile on themler.io site (log in to the site, go to Profile and check the option to get beta updates, reload themler and the theme should offer the update). Gina Themler Support
engels
engels posted this 3 days ago
20 hours ago WC was updated. +++++ Same issue again!!! ++++++++
Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 20480 bytes).....
Pleeeeaase fix it.
Thank you.
20 hours ago WC was updated. +++++ Same issue again!!! ++++++++ Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 20480 bytes)..... Pleeeeaase fix it. Thank you.
LGWeb
LGWeb posted this 2 days ago
I have version 481 and still not working. Cleared master cache on Siteground too. Change theme and it works.. so I know it is Themler theme. I submitted a ticket. see ticket I have given you the login for the WP site. Please fix asap. My client is losing money. All my template files have been updated as well.
engels
engels posted this 23 hours ago
No! v481 isn't the solution.
Beta v481 was to solve an equal error several weeks ago.
Last week there was a new wc update - and same error again!
No! v481 isn't the solution. Beta v481 was to solve an equal error several weeks ago. Last week there was a new wc update - and same error again!
Support Team posted this 21 hours ago
The issue is related to WooCommerce version 3.6.3, we are working on fixing it and make an update in the near future. Meanwhile, please, downgrade to WooCommerce 3.6.2. We apologize for the incovenience.
The issue is related to WooCommerce version 3.6.3, we are working on fixing it and make an update in the near future. Meanwhile, please, downgrade to WooCommerce 3.6.2. We apologize for the incovenience. Gina Themler Support
hattsho
hattsho posted this 10 hours ago
Sorry, how do I downgrade....?
> The issue is related to WooCommerce version 3.6.3, we are working on fixing it and make an update in the near future. Meanwhile, please, downgrade to WooCommerce 3.6.2. We apologize for the incovenience. > > Gina > Themler Support Sorry, how do I downgrade....?
Support Team posted this 39 min ago
You can follow the steps suggested here https://wordpress.org/support/topic/how-to-downgrade-to-previous-woocommerce-version/ or here https://themes.zone/docs/downgrade-woocommerce-needed-version-without-losing-data/
You can follow the steps suggested here https://wordpress.org/support/topic/how-to-downgrade-to-previous-woocommerce-version/ or here https://themes.zone/docs/downgrade-woocommerce-needed-version-without-losing-data/ Gina Themler Support
