Ajouter class= box filter ?
jonathan0505
jonathan0505 posted this 5 weeks ago
A close question has already been asked. Is it possible to modify / add a class and an Id to a container, a column, a button. My goal is to use the "class = box filter ...." to filter columns. Is it possible to do it directly in a template file on joomla?
In advance thank you, cordially.
Hello, A close question has already been asked. Is it possible to modify / add a class and an Id to a container, a column, a button. My goal is to use the "class = box filter ...." to filter columns. Is it possible to do it directly in a template file on joomla? In advance thank you, cordially.
It is possible to add CSS ID to a section only, inside of Themler.
You can also assign different CSS classed to Joomla modules in general (inside Joomla admin panel) or can use classed of WP widgets, depending on what template type you create. But it is not possible to add CSS class to a separate column.
If you describe what you need to filter exactly and provide the link to the page, we may think of some other solution.
Hello, It is possible to add CSS ID to a section only, inside of Themler. You can also assign different CSS classed to Joomla modules in general (inside Joomla admin panel) or can use classed of WP widgets, depending on what template type you create. But it is not possible to add CSS class to a separate column. If you describe what you need to filter exactly and provide the link to the page, we may think of some other solution. Gina Themler Support
