Fatal error for all sites with last Woocommerce Update
Kevin Doussaint
Kevin Doussaint posted this 25 April 2019
Since last Woocommerce Update all my Themler websites are broken on the cart page with this error :
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16384 bytes) in /home/www/babiolesetbricoles/wp-content/themes/MYTHEME/woocommerce/cart/cart-totals-wrapper.php on line 5
I tried to allocate more memory on php.ini or wp-config.php but did not solved the problem wich seems deeper. When I change my theme it solve the problem (wich is not present on my other themes like elementor etc...).
My server limit is 256M
And I got this report :
babiolesbricoles03/woocommerce/archive-product.php version 3.3.0 est obsolète. La version du noyau est 3.4.0,
babiolesbricoles03/woocommerce/cart/cart.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/error.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/notice.php version 1.6.4 est obsolète. La version du noyau est 3.5.0,
babiolesbricoles03/woocommerce/notices/success.php version 3.3.0 est obsolète. La version du noyau est 3.5.0,
Could you please help me ?
Best regards
Kevin
Hi, Since last Woocommerce Update all my Themler websites are broken on the cart page with this error : Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 16384 bytes) in /home/www/babiolesetbricoles/wp-content/themes/MYTHEME/woocommerce/cart/cart-totals-wrapper.php on line 5 I tried to allocate more memory on php.ini or wp-config.php but did not solved the problem wich seems deeper. When I change my theme it solve the problem (wich is not present on my other themes like elementor etc...). My server limit is 256M And I got this report : babiolesbricoles03/woocommerce/archive-product.php version 3.3.0 est obsolète. La version du noyau est 3.4.0, babiolesbricoles03/woocommerce/cart/cart.php version 3.3.0 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/error.php version 3.3.0 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/notice.php version 1.6.4 est obsolète. La version du noyau est 3.5.0, babiolesbricoles03/woocommerce/notices/success.php version 3.3.0 est obsolète. La version du noyau est 3.5.0, Could you please help me ? Best regards Kevin
15 Comments
Administración web
Administración web posted this 26 April 2019
Lo que yo hice fue Desactivar Woocommerce 3.6.1 e instalé una versión anterior, instalé la versión 3.5.7 y funcionó nuevamente, lo hice en una página de pruebas y creo que no perdí Ninguna información como productos ni nada.
Kevin Doussaint
Kevin Doussaint posted this 27 April 2019
Muchas gracias por el consejo, lo restauré pero no podemos quedarnos así con varios sitios que no actualizamos, ni siquiera tenemos una respuesta de Themler sobre cómo tener en cuenta nuestros mensajes, es una pena.
Support Team posted this 01 May 2019
Please, try now, the issue with Woocommerce is fixed, it is necessary to update Themler.
Please, try now, the issue with Woocommerce is fixed, it is necessary to update Themler. Gina Themler Support
Kevin Doussaint
Kevin Doussaint posted this 01 May 2019
Thanks, should we activate beta channel ?
Hi, Thanks, should we activate beta channel ?
It was a beta fix. The theme should "ask" you for an update when you open it in Themler.
If you have any issues with Themler Editor in Chrome, try opening it in Firefox.
It was a beta fix. The theme should "ask" you for an update when you open it in Themler. If you have any issues with Themler Editor in Chrome, try opening it in Firefox. Gina Themler Support
Kevin Doussaint
Hi Gina,
Thanks it works !
Hi Gina, Thanks it works !
Administración web
Administración web posted this 03 May 2019
Hola Gina, existe alguna forma de corregir el error para quienes no tenemos una "Suscripción activa" de Themler?
Support Team posted this 04 May 2019
Unfortunately, I can't provide exact changes we made to php files, too many changes were made in different files.
In case you don't have active subscription, it is better to stick to previous WooCommrce version that didn't have this issue.
Hello, Unfortunately, I can't provide exact changes we made to php files, too many changes were made in different files. In case you don't have active subscription, it is better to stick to previous WooCommrce version that didn't have this issue. Gina Themler Support
david33260
david33260 posted this 15 May 2019
I have the same problem but no update notification appears on themler.
Hello, I have the same problem but no update notification appears on themler.
Kevin Doussaint
Kevin Doussaint posted this 15 May 2019
Hi, You have to go in your account on themler.io and activate Beta Channel
Support Team posted this 15 May 2019
Correct. Beta updates come if this Option is active:
Correct. Beta updates come if this Option is active: !get-beta.png! Gina Themler Support
david33260
Great
Thank you for your quick reply.
Great Thank you for your quick reply.
alleminbe
alleminbe posted this 18 May 2019
I have the same problem and did all the steps above its on beta v.481 but the cart page has the same problems its shrinks, how can I fix it?
https://hulkwest.com/cart/
Thanks in advance
I have the same problem and did all the steps above its on beta v.481 but the cart page has the same problems its shrinks, how can I fix it? https://hulkwest.com/cart/ Thanks in advance
LGWeb
LGWeb posted this 19 May 2019
Thanks in advance
Same problem for me.. i submitted the ticket and login to my WP. Please fix asap.
> I have the same problem and did all the steps above its on beta v.481 but the cart page has the same problems its shrinks, how can I fix it? > > https://hulkwest.com/cart/ > > Thanks in advance Same problem for me.. i submitted the ticket and login to my WP. Please fix asap.
engels
engels posted this 20 May 2019
No! v481 isn't the solution.
Beta v481 was to solve an equal error several weeks ago.
Last week there was a new wc update - and same error again!
No! v481 isn't the solution. Beta v481 was to solve an equal error several weeks ago. Last week there was a new wc update - and same error again!
