Change text color based on value
Orange Gorilla
Orange Gorilla posted this 07 May 2019
I would like to change the color based on a value.
For example:
when a text field / or value (text in CMS block) is "A", the background should be blue. When the value is "B" the background should be green.
How Can I create something like that with Themler?
Kind regards,
Hi, I would like to change the color based on a value. For example: when a text field / or value (text in CMS block) is "A", the background should be blue. When the value is "B" the background should be green. How Can I create something like that with Themler? Kind regards,
9 Comments
Support Team posted this 08 May 2019
Could you please explain about the values? Where will they come from? Is it dynamic code?
Hello, Could you please explain about the values? Where will they come from? Is it dynamic code? Gina Themler Support
Orange Gorilla
Orange Gorilla posted this 08 May 2019
I use advanced custom field (cms block).
Please, provide the link to the page and describe where we can see those fields.
Please, provide the link to the page and describe where we can see those fields. Gina Themler Support
Orange Gorilla
It's about this page: http://gigmanager.orangegorilla.nl/
Third column. The value on this page is for 'Bevestigd', 'Optie' or 'B'.
Now i'm working with CMS blocks with a ACF code.
It's about this page: http://gigmanager.orangegorilla.nl/ Third column. The value on this page is for 'Bevestigd', 'Optie' or 'B'. Now i'm working with CMS blocks with a ACF code.
Orange Gorilla
Orange Gorilla posted this 10 May 2019
Someone?
Someone?
Support Team posted this 11 May 2019
You can try using this code, but please note that I can only make the background of that field change (not entire row):
div[class*="populationc"] {
  background-color:red!important;
div[class*="populationa"] {
  background-color:green!important;
You can try using this code, but please note that I can only make the background of that field change (not entire row): div[class*="populationc"] { background-color:red!important; } div[class*="populationa"] { background-color:green!important; } Gina Themler Support
Orange Gorilla
Orange Gorilla posted this 11 May 2019
Thanks.
Do I have to add this code in the concerning Cms block?
Hi, Thanks. Do I have to add this code in the concerning Cms block?
Orange Gorilla
Already figured it out, thanks.
Support Team posted this 12 May 2019
Ok, good. But just in case: it can be added in Themler -> Home -> Settings -> Additional CSS or directly on the site to template.css.
Ok, good. But just in case: it can be added in Themler -> Home -> Settings -> Additional CSS or directly on the site to template.css. Gina
