I need lightbox instead of magnifier in WooCoommerce.
info1938
info1938 posted this 2 weeks ago
I know how to hide the magnifier, but it 's not an entirely working solution.
I need to know how to enable the lightbox instead of the magnifier.
I need to use a lightbox on my product details , not magnifier.
Hope you have a solution, saw that people are asking you for the same option since 2016 (3 years ago).
Hello, I know how to hide the magnifier, but it 's not an entirely working solution. I need to know how to enable the lightbox instead of the magnifier. I need to use a lightbox on my product details , not magnifier. Hope you have a solution, saw that people are asking you for the same option since 2016 (3 years ago).
info1938
In addition, yes, I activated the lightbox support in my theme's functions.php
It's just still not working.
Used a sample of this code:
add_action( 'after_setup_theme', 'yourtheme_setup' );
function yourtheme_setup() {
add_theme_support( 'wc-product-gallery-zoom' );
add_theme_support( 'wc-product-gallery-lightbox' );
add_theme_support( 'wc-product-gallery-slider' );
In addition, yes, I activated the lightbox support in my theme's functions.php It's just still not working. Used a sample of this code: add_action( 'after_setup_theme', 'yourtheme_setup' ); function yourtheme_setup() { add_theme_support( 'wc-product-gallery-zoom' ); add_theme_support( 'wc-product-gallery-lightbox' ); add_theme_support( 'wc-product-gallery-slider' ); }
info1938
Also, I tried with several plugins that are working on other non themler themes, but are conflicting with Themler.
info1938
Okay, I found a plugin that is almost working .
But it's conflicting with the themler product details template.
Can I use the dafault woocommerce theme and disable product details themler template only for this page - Product Details?
I know how to disable all store templates, but this is not an option right now.
Okay, I found a plugin that is almost working . But it's conflicting with the themler product details template. Can I use the dafault woocommerce theme and disable product details themler template only for this page - Product Details? I know how to disable all store templates, but this is not an option right now.
Hello Milla,
You mentioned that the last plugin you tried was almost working.
Could you please specify what the issues were? Maybe, we can fix them using custom CSS.
Hello Milla, You mentioned that the last plugin you tried was almost working. Could you please specify what the issues were? Maybe, we can fix them using custom CSS. Gina Themler Support
