Always the same problem when starting Themler : 127.0.0.1:12080
bruno.nicolas
bruno.nicolas posted this 09 May 2019
Hello !
I have always the same problem with Themler.
When Themler is starting, i have this error : 127.0.0.1:12080 indique Retry ?
What can i do ?
Error log in attachments.
Thanks for your help and have a nice day.
Bruno Nicolas
Hello ! I have always the same problem with Themler. When Themler is starting, i have this error : 127.0.0.1:12080 indique Retry ? What can i do ? Error log in attachments. Thanks for your help and have a nice day. Bruno Nicolas
11 Comments
Support Team posted this 09 May 2019
We are sorry for the issue, our developers are working at fixing it. Could you please temporarily use Firefox browser to run Themler using this link:
http://127.0.0.1:12080/themler_1252863909/startup/
Hello, We are sorry for the issue, our developers are working at fixing it. Could you please temporarily use Firefox browser to run Themler using this link: http://127.0.0.1:12080/themler_1252863909/startup/ Sincerely, Nettie
bruno.nicolas
Thanks for the support.
No problem with Firefox ;-)
Hello, Thanks for the support. No problem with Firefox ;-)
contacto19
contacto19 posted this 10 May 2019
I also have that error. (view image).
The link in firefox does not work.
I can not do anything.
a greeting.
Hello I also have that error. (view image). The link in firefox does not work. I can not do anything. a greeting.
wieland.kleinert
wieland.kleinert posted this 10 May 2019
allways error, error...
nothing works
Server-error
SyntaxError: Unexpected end of JSON input
http://cstatic.themler.ii/controls/439/controls_presets.json
why, why, why?
allways error, error... nothing works Server-error SyntaxError: Unexpected end of JSON input http://cstatic.themler.ii/controls/439/controls_presets.json why, why, why?
Support Team posted this 13 May 2019
We apologize for the issue, we are working on it.
You should be able to open Themler in Firefox though. Please try to run the URL like this in a browser:
The numbers instead of XXXXXXXXXX are individual and can be found at the path like C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx
We apologize for the issue, we are working on it. You should be able to open Themler in Firefox though. Please try to run the URL like this in a browser: http://127.0.0.1:12080/themler_XXXXXXXXXX/startup/ The numbers instead of XXXXXXXXXX are individual and can be found at the path like C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx Gina Themler Support
Support Team posted this 14 May 2019
The issue is fixed, but in order to open the website correctly the following steps are recommended:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Hello, The issue is fixed, but in order to open the website correctly the following steps are recommended: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Sincerely, Nettie
assistenza.storm
assistenza.storm posted this 17 May 2019
now I take everything you write with pliers. Have you solved it? but really! you have a technical department of incompetents that's the reality. I reinstalled chrome, made the steps you indicated and continues to fail in the desktop version. What is the point in offering a desktop version based on chrome if we then have to work directly on the host with firefox? answer this. The problem of 127.0.0.1:12080 continues to present itself also cleaning the cache and images and also removing the sites from memory. Solve this problem because it is already a month that it is impossible to use the program
> Hello, > > The issue is fixed, but in order to open the website correctly the following steps are recommended: > 1) Open this URL in Chrome: > chrome://appcache-internals > find your website and click on 'Remove Item' > > 2) Open this URL in Chrome: > chrome://settings/clearBrowserData > select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). > > 3) Reload your Themler Editor. > > Sincerely, > Nettie now I take everything you write with pliers. Have you solved it? but really! you have a technical department of incompetents that's the reality. I reinstalled chrome, made the steps you indicated and continues to fail in the desktop version. What is the point in offering a desktop version based on chrome if we then have to work directly on the host with firefox? answer this. The problem of 127.0.0.1:12080 continues to present itself also cleaning the cache and images and also removing the sites from memory. Solve this problem because it is already a month that it is impossible to use the program
8055540
8055540 posted this 17 May 2019
Same problem! Please, solve it urgently!
I use Chrome and do not install Firefox.
SyntaxError; Unexpected end of JSON input
http://cstatic.themler.io/controls/473/controls_presets.json
Same problem! Please, solve it urgently! I use Chrome and do not install Firefox. SyntaxError; Unexpected end of JSON input http://cstatic.themler.io/controls/473/controls_presets.json
8055540
It is so strange... Dear Themler team, you have the answer for this problem. Why you don't know the answer?!
Dear customers, I solved my problem by
Alternative method
Close Themler.
Find and rename c:\Users\user_name\AppData\Local\Themler\ChromeData folder (e.g. "ChromeData_1").
Open Themler.
I found it here: http://answers.themler.io/articles/13879/themler-desktop-troubleshooting
It is so strange... Dear Themler team, you have the answer for this problem. Why you don't know the answer?! Dear customers, I solved my problem by Alternative method Close Themler. Find and rename c:\Users\user_name\AppData\Local\Themler\ChromeData folder (e.g. "ChromeData_1"). Open Themler. I found it here: http://answers.themler.io/articles/13879/themler-desktop-troubleshooting
8055540
Hello !
What can i do ?
<skipped>
Alternative method
Close Themler.
Open Themler.
> Hello ! > > I have always the same problem with Themler. > When Themler is starting, i have this error : 127.0.0.1:12080 indique Retry ? > > What can i do ? > &lt;skipped&gt; I solved my problem by Alternative method Close Themler. Find and rename c:\Users\user_name\AppData\Local\Themler\ChromeData folder (e.g. &quot;ChromeData_1&quot;). Open Themler. I found it here: http://answers.themler.io/articles/13879/themler-desktop-troubleshooting
Support Team posted this 18 May 2019
The issue should be fixed now. If it is still present in Themler for Windows, please try the following:
1) close Themler
4) start Themler again
Hello, The issue should be fixed now. If it is still present in Themler for Windows, please try the following: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Please let us know the result. Sincerely, Nettie
