Problem with Social Links feature for the header
David at Acoma
David at Acoma posted this 5 days ago
I think there is a problem when inserting a link to a facebook page and ask for it to be treated as a static URL, Themler currently converts that to a share page link, which is not what we need. we have share icons elsewhere these are links to the facebook page itself.
If I switch the URL to Static URL with Share, it does that same thing, which is correct for static url with share, but its not meant to be the same when you use Static URL only.
The only solution I have is to not use your Social group feature and go with manual icons and wrap a link on them, which is time-consuming.
PS also any news on this Chrome issue, as I develop in Chrome but now need to use Firefox on Themler and the rest in Chrome.
I think there is a problem when inserting a link to a facebook page and ask for it to be treated as a static URL, Themler currently converts that to a share page link, which is not what we need. we have share icons elsewhere these are links to the facebook page itself. If I switch the URL to Static URL with Share, it does that same thing, which is correct for static url with share, but its not meant to be the same when you use Static URL only. The only solution I have is to not use your Social group feature and go with manual icons and wrap a link on them, which is time-consuming. PS also any news on this Chrome issue, as I develop in Chrome but now need to use Firefox on Themler and the rest in Chrome.
Support Team posted this 4 days ago
Hello David,
Under Insert menu tab in Themler you can add Social Links (which is used only for sharing purposes) or Icon. When inserting an Icon, you can (as you mentioned) pick a social icon image and add a link to social media. This is standard options for adding links to social media.
As for the issue with Chrome, try this:
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Hello David, Under Insert menu tab in Themler you can add Social Links (which is used only for sharing purposes) or Icon. When inserting an Icon, you can (as you mentioned) pick a social icon image and add a link to social media. This is standard options for adding links to social media. As for the issue with Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
David at Acoma
David at Acoma posted this 4 days ago
Thank you for the Chrome Themler issue advice, worked!
On the Social Icons feature. Please take a link, I was not asking how you create the icon, but I was talking about the setting not working. See attached files.
I want a static URL and not a share URL But regardless of setting, this triggers the share FB function.
Thank you for the Chrome Themler issue advice, worked! On the Social Icons feature. Please take a link, I was not asking how you create the icon, but I was talking about the setting not working. See attached files. I want a static URL and not a share URL But regardless of setting, this triggers the share FB function.
David at Acoma
David at Acoma posted this 8 hours ago
Hello??
Hello??
