imposible to login in to edit a template in joomla
themler134
themler134 posted this 4 days ago
I have a valid subscription.
I install the themler template to edit in joomla
then when a chose a section, there is a popup to login.
It's impossible to login.
But my login works on themler.io
my user : Themler@lurik.fr
i use the last version of joomla and last version of firefox.
I have a valid subscription. I install the themler template to edit in joomla then when a chose a section, there is a popup to login. It's impossible to login. But my login works on themler.io my user : Themler@lurik.fr i use the last version of joomla and last version of firefox.
Support Team posted this 4 days ago
Hello Olivier,
What does it say when you try to login? That the credentials are not valid?
Hello Olivier, What does it say when you try to login? That the credentials are not valid? Gina Themler Support
