Hello, I would like to change breakpoints manually in css. If I do it then the themler will work and if it is saved or updated it will not be replaced.
The big problem is when you make a page for 1920x1080 and 1366x768 resolution to make it look nice
Hello, I would like to change breakpoints manually in css. If I do it then the themler will work and if it is saved or updated it will not be replaced. The big problem is when you make a page for 1920x1080 and 1366x768 resolution to make it look nice
