Background picture for whole page
admin166
admin166 posted this 03 June 2019
With me the background picture appears again "chopped off". See attached file.
It seems so, so two pictures are deposited. If I change the background image under "Design", only the lower part changes. How can it change completely for the whole page?
Hello With me the background picture appears again "chopped off". See attached file. It seems so, so two pictures are deposited. If I change the background image under "Design", only the lower part changes. How can it change completely for the whole page?
Support Team posted this 03 June 2019
Please try to change first not the image itself but the way it is used, for example, "Cover". The settings for the image positioning can be wound under the Background Image >> More on the right panel.
Hello, Please try to change first not the image itself but the way it is used, for example, "Cover". The settings for the image positioning can be wound under the Background Image >> More on the right panel. Sincerely, Nettie
admin166
Is Solution
admin166 posted this 05 June 2019
Thanks for the answer.
Although this did not fix the problem. But now I saw that the header also had a background image. I didn't see this in the setting. After I clicked on "delete" under more advanced options, it was gone.
So it's done.
Hello Thanks for the answer. Although this did not fix the problem. But now I saw that the header also had a background image. I didn't see this in the setting. After I clicked on "delete" under more advanced options, it was gone. So it's done.
Support Team posted this 05 June 2019
Great, thanks for letting us know. Please feel free to contact us in any other case.
Great, thanks for letting us know. Please feel free to contact us in any other case. Sincerely, Nettie
