Why my Banners not rotating
kostianev
kostianev posted this 11 June 2019
Hello I need support for one bug fix,
I added joomla module position called BannerHome for example, where I publish standard Joomla banner module there with 2 banners. But when I mark to show more than 1 banner, the banners are displayed one under one, not in 1 position and rotating.
This is standard function to rotate banners in 1 module position, but there is some bug in Themler I think. Can you assist me?
I need the two banners rotating in every impression, not displayed all in all the time.
Hello I need support for one bug fix, I added joomla module position called BannerHome for example, where I publish standard Joomla banner module there with 2 banners. But when I mark to show more than 1 banner, the banners are displayed one under one, not in 1 position and rotating. This is standard function to rotate banners in 1 module position, but there is some bug in Themler I think. Can you assist me? I need the two banners rotating in every impression, not displayed all in all the time.
Support Team posted this 13 June 2019
Hello Aleksandar,
You need to add a slider in Themler to that position to make sure the banners rotate.
Hello Aleksandar, You need to add a slider in Themler to that position to make sure the banners rotate. Gina Themler Support
