Hi.
Google Chrome DevTool show that jQuery library from Themler is outdated and have known security vulnerabilities.
The questions:
1. Why Themler use jQuery v1.11.1 instead v3.4.x?
2. Can we manually replace v1.11.1 to v3.4.1?
Hi.
The questions:
Can we manually update jQuery library v1.11.1 to v3.4.1? This will not break Themler?
Can we manually update jQuery library v1.11.1 to v3.4.1? This will not break Themler?Wow, I was not aware of this issue. This is of the utmost importance to be updated. Any security related issues should be addressed asap. Not a feature request here. https://snyk.io/vuln/npm:jquery:20150627
This is quite old as well. Themler, please address this.
Wow, I was not aware of this issue. This is of the utmost importance to be updated. Any security related issues should be addressed asap. Not a feature request here. https://snyk.io/vuln/npm:jquery:20150627 This is quite old as well. Themler, please address this.Has this been fixed? If it has not why not?
Has this been fixed? If it has not why not?As I understood and read, jquery in Joomla 4 is completely gone.?
Greetings..
This does indeed need adressing, but can be worked around in the mean time with the jQueryEasy extension
This does indeed need adressing, but can be worked around in the mean time with the jQueryEasy extensionUPSers has created an online portal to make the life of its employees easy. upserscom portal allows its employees to log in to the portal and access services like their payrolls, refunds, and many more.
UPSers has created an online portal to make the life of its employees easy. [upserscom][1] portal allows its employees to log in to the portal and access services like their payrolls, refunds, and many more. [1]: https://upserss.xyz/
