Themler + Nicepage Framework
DaveOzric
DaveOzric posted this 3 weeks ago
Hello, I mostly use Joomla and wonder if Themler and Nicepage can be like the other top Joomla developer's multi-site creation systems. The top template designers have a page builder for their clients to use along with the theme maker. They share the same libraries so it's only loading one set of BS & CSS for both.
This would be ideal for what you have now. Why don't you ask the developers if that is the plan and explain that to us? It would make us all so much more confident you are not abandoning us like Artisteer.
I want separate products.
Hello, I mostly use Joomla and wonder if Themler and Nicepage can be like the other top Joomla developer's multi-site creation systems. The top template designers have a page builder for their clients to use along with the theme maker. They share the same libraries so it's only loading one set of BS & CSS for both. This would be ideal for what you have now. Why don't you ask the developers if that is the plan and explain that to us? It would make us all so much more confident you are not abandoning us like Artisteer. I want separate products.
DaveOzric
Joomshaper is the top page builder with the Helix template framework. They work perfectly together and do separate things.
Vitaliy WD
Vitaliy WD posted this 3 weeks ago
I tested Themler + Nicepage at the end of 2018 and Nicepage worked then incorrect. There is 3 option how Nicepage can work with Joomla article and Themler. Variant to use Nicepage with Themler without Nicepage Header/Footer works not properly. Different results between Nicepage editor and at real website. I do all possible variants, playing with Themler and Nicepage layout... with no luck. This was a bug, don't know if they fixed this now.
And need to know that Nicepage have own framework so Themler + Nicepage will generate a huge amount of code... Google will not give good rank for this.
I tested Themler + Nicepage at the end of 2018 and Nicepage worked then incorrect. There is 3 option how Nicepage can work with Joomla article and Themler. Variant to use Nicepage with Themler without Nicepage Header/Footer works not properly. Different results between Nicepage editor and at real website. I do all possible variants, playing with Themler and Nicepage layout... with no luck. This was a bug, don't know if they fixed this now. And need to know that Nicepage have own framework so Themler + Nicepage will generate a huge amount of code... Google will not give good rank for this.
In general Themler and nicepage are two different applications with independant frameworks. Though it is possible to use both Themler and Nicepage in Joomla at the same time. Nicepage, in this case, is used for building the content, while Themler provides the theme (styling). They are not linked and affect each other.
Hello, In general Themler and nicepage are two different applications with independant frameworks. Though it is possible to use both Themler and Nicepage in Joomla at the same time. Nicepage, in this case, is used for building the content, while Themler provides the theme (styling). They are not linked and affect each other. Gina Themler Support
