Three weeks ago and stil no answer
RLuka
RLuka posted this 05 July 2019
I installed Themler on my new iMac, but I can't open the files. I see only a white screen.
Solution please
Ray
Hi, I installed Themler on my new iMac, but I can't open the files. I see only a white screen. Solution please Thanks Ray
9 Comments
Support Team posted this 05 July 2019
Please try completely uninstalling Themler and also remove Themler folder from the Mac library. Then temporarily disable antivirus and firewall, download and install Themler for Mac anew. Please make sure to backup all the created themes before this, if there are any.
Hello, Please try completely uninstalling Themler and also remove Themler folder from the Mac library. Then temporarily disable antivirus and firewall, download and install Themler for Mac anew. Please make sure to backup all the created themes before this, if there are any. Sincerely, Nettie
RLuka
RLuka posted this 09 August 2019
Hi Nettie,
I tried it all, but it doesn't work. I imported the zip file, copied the files to the Themler under hd_data, but no succes.
I see the frontpage when I click on open (see attachment), but when I tried to open it, I see a white screen.
Hi Nettie, I tried it all, but it doesn't work. I imported the zip file, copied the files to the Themler under hd_data, but no succes. I see the frontpage when I click on open (see attachment), but when I tried to open it, I see a white screen.
Support Team posted this 13 August 2019
Do you see a white screen when you open a new theme or any theme? Also - does the issue happen in Themler for HTML only or also with Themler for CMS like Wordpress?
Hello, Do you see a white screen when you open a new theme or any theme? Also - does the issue happen in Themler for HTML only or also with Themler for CMS like Wordpress? Sincerely, Nettie
RLuka
RLuka posted this 24 August 2019
I think the problem is that Themler doesn't work correctly because it's a 32 bit app and it doesn't work good with Mojave.
Hi, I think the problem is that Themler doesn't work correctly because it's a 32 bit app and it doesn't work good with Mojave.
Support Team posted this 26 August 2019
Could you please specify the questions from the previous post? In the meantime please consider using Themler in an alternative way - by running it in your CMS on sme localhost or hosted website.
Hello, Could you please specify the questions from the previous post? In the meantime please consider using Themler in an alternative way - by running it in your CMS on sme localhost or hosted website. Sincerely, Nettie
RLuka
RLuka posted this 27 August 2019
I see this (see attachment) When I try to open de file, I see a white screen. Nothing happen.
Maybe a file is missing, but I don't know for sure.
How can I fix this?
I see this (see attachment) When I try to open de file, I see a white screen. Nothing happen. Maybe a file is missing, but I don't know for sure. How can I fix this?
Support Team posted this 28 August 2019
What happens if you press Create new theme? What happens if you open an existing theme? What is the result if you try to paste this link into Safari or Firefox browser and open Themler:
http://127.0.0.1:29958/themler_2279526072/startup/
Does the issue exist with Themler for HTML only or also with Themler for Wordpress or for Joomla?
Hello, What happens if you press Create new theme? What happens if you open an existing theme? What is the result if you try to paste this link into Safari or Firefox browser and open Themler: http://127.0.0.1:29958/themler_2279526072/startup/ Does the issue exist with Themler for HTML only or also with Themler for Wordpress or for Joomla? Sincerely, Nettie
RLuka
RLuka posted this 28 August 2019
No Only with HTML. I used HTML to design the website.
if I start a new one with HTML, then it works fine.
No Only with HTML. I used HTML to design the website. if I start a new one with HTML, then it works fine.
RLuka
RLuka posted this 22 September 2019
I tried everything, but I don't; get it to work.
Can you fix the problem when I send the files to you?
Hi, I tried everything, but I don't; get it to work. Can you fix the problem when I send the files to you?
