Edit the /checkout/order-received Page
petra
petra posted this 12 July 2019
Hi Guys
I need to make changes to the page that you get after a client has made payment in Woocomerce
Where and how do I do that.
See attached to 'see' page I'm talking about.
Hi Guys I need to make changes to the page that you get after a client has made payment in Woocomerce Where and how do I do that. See attached to 'see' page I'm talking about.
Support Team posted this 12 July 2019
For this page design global styles (set in the Design tab) are used in Themler. Content of the page is defined by Woocommerce and cannot be changed in Themler. To change the fields from Woocommerce, there are possible solutions in the Internet including special plugins, for example:
https://wordpress.org/plugins/woo-checkout-field-editor-pro/
Hello, For this page design global styles (set in the Design tab) are used in Themler. Content of the page is defined by Woocommerce and cannot be changed in Themler. To change the fields from Woocommerce, there are possible solutions in the Internet including special plugins, for example: https://wordpress.org/plugins/woo-checkout-field-editor-pro/ Sincerely, Nettie
petra
I have tried to edit it in the page design, but then I loose my format on all the pages.
How can I set the page to have a bit of padding on the sides without loosing my fluid-ness?
Hi I have tried to edit it in the page design, but then I loose my format on all the pages. How can I set the page to have a bit of padding on the sides without loosing my fluid-ness?
Please try to edit styles for the green area (CMS Content) only. These changes should be reflected only on the selected page.
Hello, Please try to edit styles for the green area (CMS Content) only. These changes should be reflected only on the selected page. Sincerely, Nettie
petra
petra posted this 15 July 2019
Hi Nettie
The the problem is, I don't know how to browse to that page so that I can just edit that specific page?
I know I can brows on the menu to by right click and say open link->
But I don't know how to get to the page, it is only generated after an order has been processed.
The closes-ed I can get is
http://www.cakeboys.co.za/checkout/order-received/
That is the thank you page... but still I don't know how to get to it so I can edit the CSS as you say.
Hi Nettie The the problem is, I don't know how to browse to that page so that I can just edit that specific page? I know I can brows on the menu to by right click and say open link-> But I don't know how to get to the page, it is only generated after an order has been processed. The closes-ed I can get is http://www.cakeboys.co.za/checkout/order-received/ That is the thank you page... but still I don't know how to get to it so I can edit the CSS as you say.
Support Team posted this 15 July 2019
You can consider making a test order and managing it then from CMS.
Hello, You can consider making a test order and managing it then from CMS. Sincerely, Nettie
