Server Error Themler Desktop
HarthMediadesign
HarthMediadesign posted this 15 July 2019
Good evening,
Since yesterday, my Themler is no longer :( I have purchased the latest version about 3 weeks ago When importing a Billion Themes (ZIP) I get the following message.
Picture Fail:
https://ibb.co/RcL2WwM
or
https://ibb.co/zZJvyQv
I had this problem before
C:\ProgramData\Themler
  1. If they exist, remove them.
  2. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure.
  3. Download latest version of Themler for Windows from themler.com, install it and try to start with any CMS and create a theme.
Relating Artisteer projects. It is possible, to import Artisteer themes in Themler: for Joomla, Wordpress and HTML Export. Please use this latest Artisteer version, the special export types for Themler are present there in the Export drop-down:
After the reinstallation based on the instructions came above problem
Greets Tobi
Good evening, Since yesterday, my Themler is no longer :( I have purchased the latest version about 3 weeks ago When importing a Billion Themes (ZIP) I get the following message. Picture Fail: https://ibb.co/RcL2WwM or https://ibb.co/zZJvyQv **I had this problem before** Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Download latest version of Themler for Windows from themler.com, install it and try to start with any CMS and create a theme. Please let us know the result. Relating Artisteer projects. It is possible, to import Artisteer themes in Themler: for Joomla, Wordpress and HTML Export. Please use this latest Artisteer version, the special export types for Themler are present there in the Export drop-down: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie, BillionDigital Team **After the reinstallation based on the instructions came above problem** Greets Tobi
6 Comments
HarthMediadesign
The problem still exists!
https://ibb.co/HdzDgsB
The problem still exists! https://ibb.co/HdzDgsB
Support Team posted this 16 July 2019
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Hello, If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
HarthMediadesign
HarthMediadesign posted this 16 July 2019
Thanks for the answer. The import from the ZIP file has now worked. But unfortunately not importing in the desktop version of Billion Themes.
I still get the Error 127.0.0.1:12080
Thanks for the answer. The import from the ZIP file has now worked. But unfortunately not importing in the desktop version of Billion Themes. I still get the Error 127.0.0.1:12080
Support Team posted this 17 July 2019
Please, do the steps for desktop version once again. If it still doesn't work, please, do the following:
Please, do the steps for desktop version once again. If it still doesn't work, please, do the following: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for any CMS and create a theme. Gina Themler Support
HarthMediadesign
HarthMediadesign posted this 18 July 2019
it works!
Thanks!
greets
Tobi
Hi, it works! Thanks! greets Tobi
Support Team posted this 18 July 2019
Themler Team
You are welcome! Please feel free to contact us in any other case. Sincerely, Themler Team
