How to migrate themler application to another server and account?
jordantsap
jordantsap posted this 25 July 2019
Hello i want to migrate customers themler joomla template that is installed already to another server.
Please help
Hello i want to migrate customers themler joomla template that is installed already to another server. Please help
Support Team posted this 26 July 2019
A theme can be copied via FTP and installed in another Joomla. Also you may export a theme from Themler, optionally including content. But to transfer the website completely including all content, modules and menus, special ways and tools are recommended. For example, there exist plugins for website transfer.
Hello, A theme can be copied via FTP and installed in another Joomla. Also you may export a theme from Themler, optionally including content. But to transfer the website completely including all content, modules and menus, special ways and tools are recommended. For example, there exist plugins for website transfer. Sincerely, Nettie
jordantsap
jordantsap posted this 26 July 2019
I just want to migrate the frontend template to another joomla installation.
The current themler app is in another server by another user so i cannot export it since it asks for a licence.
I migrated the current themler folder to my localhost using the discover option joomla provides and installed the template.
Clicking at the edit template button, popup shows with following error:
[PHP_ERROR]{"message":"\n\nOS: Linux parrot 4.19.0-parrot4-28t-amd64 #1 SMP Parrot 4.19.28-2parrot4.28t (2019-04-18) x86_64\nPHP: 7.3.7\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"/opt/lampp/htdocs/joomla/templates/dermis_clinic/app/classes/Helper.php","line":586}[PHP_ERROR]
What's that mean or how i can fix it??
I just want to migrate the frontend template to another joomla installation. The current themler app is in another server by another user so i cannot export it since it asks for a licence. I migrated the current themler folder to my localhost using the discover option joomla provides and installed the template. Clicking at the edit template button, popup shows with following error: [PHP_ERROR]{"message":"\n\nOS: Linux parrot 4.19.0-parrot4-28t-amd64 #1 SMP Parrot 4.19.28-2parrot4.28t (2019-04-18) x86_64\nPHP: 7.3.7\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"\/opt\/lampp\/htdocs\/joomla\/templates\/dermis_clinic\/app\/classes\/Helper.php","line":586}[PHP_ERROR] What's that mean or how i can fix it??
Do Joomla versions in both cases differ? I mean, there can be a similar issue if the theme is not updated and you install it on Joomla 3.9. In this case it is recommended to update the theme fin the initial location first.
Hello, Do Joomla versions in both cases differ? I mean, there can be a similar issue if the theme is not updated and you install it on Joomla 3.9. In this case it is recommended to update the theme fin the initial location first. Sincerely, Nettie
