A lot of bugs....
svl1988
svl1988 posted this 3 weeks ago
I use this software almost a year now, but so many bugs :(
After I publish the website the menu was incorrect, also pictures who are local and not visible. I open a earlier saved template, but after opening the older template it was imiditly online without publishing...
Also when you click on the undo button things get worser and worser and also direct visible when visiting the website without publishing.
When I resolve a problem there is after saving a lot of other problems on the template. A lot of work for nothing!
I use this software almost a year now, but so many bugs :( After I publish the website the menu was incorrect, also pictures who are local and not visible. I open a earlier saved template, but after opening the older template it was imiditly online without publishing... Also when you click on the undo button things get worser and worser and also direct visible when visiting the website without publishing. When I resolve a problem there is after saving a lot of other problems on the template. A lot of work for nothing!
Hello Stephan,
I am very sorry that you had such experience with Themler.
If you still use the progam and have current issues, let us know.
We also recommend to use latest version 484 (which is beta, so you need to allow beta updates under your account on themler.io).
Hello Stephan, I am very sorry that you had such experience with Themler. If you still use the progam and have current issues, let us know. We also recommend to use latest version 484 (which is beta, so you need to allow beta updates under your account on themler.io). Gina Themler Support
