Themler sais invalid joomla theme
wimvandekerckhove
wimvandekerckhove posted this 31 July 2019
Last year made a theme and uploaded to site. Now need to make some changes, and themler sais invalid theme. I know for a fact that the theme has been designed with themler. First tried importing the last known zip. "Sorry can only import joomla templates". WELL IT IS ONE! Then tried going into FTP, grabbing the template folder, zip it and import that one. Aint working either
Support Team posted this 31 July 2019
Please make sure the theme was exported with "Include Themler" option enabled. If not, it can be installed, but cannot be further edited in Themler.
Other variant would be, in case you have created a theme with Themler desktop, to find this theme locally with a path like C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Hello, Please make sure the theme was exported with "Include Themler" option enabled. If not, it can be installed, but cannot be further edited in Themler. Other variant would be, in case you have created a theme with Themler desktop, to find this theme locally with a path like C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Sincerely, Nettie
wimvandekerckhove
It wasn't exported, i never do. That increases the zip size significantly. templates were created with desktop app
Support Team posted this 01 August 2019
Hello Wim,
If Themler Editor wasn't included in the theme, this theme wouldn't open in Themler.
Have you found a copy of the theme on local drive as Nettie suggested?
Hello Wim, If Themler Editor wasn't included in the theme, this theme wouldn't open in Themler. Have you found a copy of the theme on local drive as Nettie suggested? Gina Themler Support
wimvandekerckhove
wimvandekerckhove posted this 03 August 2019
i had the zip, so exported that one. As i said, failed to import. so grabbed the FTP copy, copied it to "themler_xxxx\joomla\templates, doesn't get detected
Support Team posted this 07 August 2019
Sorry for the delay.
If the theme was exported without Themler Editor included, there is no way to open it again in Themler.
I was hoping that you have original theme under ..themler_xxxx\joomla\templates (not the copy from ftp).
You either need to have exported theme with Themler Editor included or saved theme in Themler format (as you get when you go to File -> Save). No other file can be opened back with Themler.
Sorry for the delay. If the theme was exported without Themler Editor included, there is no way to open it again in Themler. I was hoping that you have original theme under ..themler_xxxx\joomla\templates (not the copy from ftp). You either need to have exported theme with Themler Editor included or saved theme in Themler format (as you get when you go to File -> Save). No other file can be opened back with Themler. Gina Themler Support
