Problem with allignment
svl1988
svl1988 posted this 3 weeks ago
Hi, I have problems with the alignment of pictures on mobile phones. De settings are identical, but as you can see the pictures are not the same format and not correct alligned.
Is there a sollution for this?
enter image description here
On the pc (big screen) it works fine.
Hi, I have problems with the alignment of pictures on mobile phones. De settings are identical, but as you can see the pictures are not the same format and not correct alligned. Is there a sollution for this? ![enter image description here][1] On the pc (big screen) it works fine. [1]: http://i67.tinypic.com/2u765xu.png
Hello Stephan,
Unfortunately, your screenshot hasn't come through, could you, please, re-attach it and provide link to your site?
Hello Stephan, Unfortunately, your screenshot hasn't come through, could you, please, re-attach it and provide link to your site? Gina Themler Support
svl1988
H,
Thanks for your replay.
You can see the problem on a mobile device by visiting the website Both images have the exact same settings, but both are different on a mobile.
H, Thanks for your replay. You can see the problem on a mobile device by visiting the [website][1] Both images have the exact same settings, but both are different on a mobile. [1]: http://isabellamake-upartist.com/bruid/
Second image has left margin set (it is used to separate the images in desktop mode). Try switching to phone view and removing left margins and paddings for the second image and the column it is in.
Second image has left margin set (it is used to separate the images in desktop mode). Try switching to phone view and removing left margins and paddings for the second image and the column it is in. Gina Themler Support
