Problem with joomla online export - can't open home in desktop
scullygirl818
scullygirl818 posted this 03 August 2019
So I created the template first in desktop and then exported it and imported it online. The online version does not always work correctly when adding certain things - they either don't show up or can't be deleted. So I wanted to export back to desktop, which I did.
However, when importing the zip back into the desktop version, it won't let me view "home," the program automatically jumps back to the 404 page. Blog is fine. This is a problem as I can't edit on desktop now.
So I created the template first in desktop and then exported it and imported it online. The online version does not always work correctly when adding certain things - they either don't show up or can't be deleted. So I wanted to export back to desktop, which I did. However, when importing the zip back into the desktop version, it won't let me view "home," the program automatically jumps back to the 404 page. Blog is fine. This is a problem as I can't edit on desktop now.
6 Comments
Support Team posted this 05 August 2019
Jamie,
This usually happens when Home menu item is not assigned in Joomla admin. There should be a meni item set as Home.
You can also try to rename Joomla folder on your computer under Themler's folder, the path to it would be like this C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Just name it as joomla_old, for example.
Jamie, This usually happens when Home menu item is not assigned in Joomla admin. There should be a meni item set as Home. You can also try to rename Joomla folder on your computer under Themler's folder, the path to it would be like this C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Just name it as joomla_old, for example. Gina Themler Support
scullygirl818
scullygirl818 posted this 05 August 2019
Jamie,
Gina.
I think something worse is wrong I tried creating a new template and it won't open the home page it does exactly the same thing. Looks like the program has been updated to .475, which I don't even see on the change log. I thought maybe I could download the previous version, but I don't see an option to do so.
ETA there was another update and it took me to .484 which didn't help
Edited again: I tried reopening the program, but it reverts back to .475 when I open it from the programs folder. It doesn't stay updated which is odd.
> Jamie, > This usually happens when Home menu item is not assigned in Joomla admin. There should be a meni item set as Home. > You can also try to rename Joomla folder on your computer under Themler's folder, the path to it would be like this C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla > > Just name it as joomla_old, for example. > > Gina. > Themler Support > > I think something worse is wrong I tried creating a new template and it won't open the home page it does exactly the same thing. Looks like the program has been updated to .475, which I don't even see on the change log. I thought maybe I could download the previous version, but I don't see an option to do so. ETA there was another update and it took me to .484 which didn't help Edited again: I tried reopening the program, but it reverts back to .475 when I open it from the programs folder. It doesn't stay updated which is odd.
scullygirl818
I tried to reinstall Themler. Now it won't run Joomla at all, it keeps popping up 127.0.0.1:12080 and retry? says it will reload, but it doesn't. I tried pasting the diagnostic log, but it's too long apparently. I did try typing this in my browser: http://localhost:12080/themler_3958281595/joomla
But it gives me the 404 error, which is not a surprise, as I couldn't select home in desktop to begin with (see above). I've attached the diagnostics
I tried to reinstall Themler. Now it won't run Joomla at all, it keeps popping up 127.0.0.1:12080 and retry? says it will reload, but it doesn't. I tried pasting the diagnostic log, but it's too long apparently. I did try typing this in my browser: http://localhost:12080/themler_3958281595/joomla But it gives me the 404 error, which is not a surprise, as I couldn't select home in desktop to begin with (see above). I've attached the diagnostics
Support Team posted this 06 August 2019
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
pastel
pastel posted this 06 December 2019
Jamie,
Hi.
The solution you proposed proved to be effective. Only that reinstalling pure Joomla meant that the previously created templates have disappeared, and you have to start again. Starting from the continuous work on the new template is cumbersome and annoying.
If you know that this problem occurs, then investigate the cause and try to remove it.
Janusz
> Jamie, > This usually happens when Home menu item is not assigned in Joomla admin. There should be a meni item set as Home. > You can also try to rename Joomla folder on your computer under Themler's folder, the path to it would be like this C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla > > Just name it as joomla_old, for example. > > Gina > Themler Support > > Hi. The solution you proposed proved to be effective. Only that reinstalling pure Joomla meant that the previously created templates have disappeared, and you have to start again. Starting from the continuous work on the new template is cumbersome and annoying. If you know that this problem occurs, then investigate the cause and try to remove it. Regards Janusz
Support Team posted this 08 December 2019
Before reinstalling, you can backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress.
Before reinstalling, you can backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress. Gina Themler Support
