Flip hover
plexforce
plexforce posted this 08 August 2019
Im using themler for many years and still love it.
Now i have a question.
I have a container, with 3 columns with text and image.
I want when I hover over the column, that the column flips to back and that I can insert on the back more information.
When you mouse moves futher, the column goes into default position.
I have looked into animated, and it almost want i want. But I cannot insert more text to back side.
Is this possible? If yes, how?
Thank you.
Hi, Im using themler for many years and still love it. Now i have a question. I have a container, with 3 columns with text and image. I want when I hover over the column, that the column flips to back and that I can insert on the back more information. When you mouse moves futher, the column goes into default position. I have looked into animated, and it almost want i want. But I cannot insert more text to back side. Is this possible? If yes, how? Thank you.
plexforce
I found an example.
I want like this:
https://www.w3schools.com/howto/howto_css_flip_card.asp
But then for the column.
I found an example. I want like this: https://www.w3schools.com/howto/howto_css_flip_card.asp But then for the column.
Support Team posted this 08 August 2019
Hello Leslie,
There is no exact such animation but you can achieve something similar using Hover Box control (via Insert menu): https://answers.themler.io/articles/8397/hover-box
Try applying different animation effects and motions in hover box settings.
Themler support
Hello Leslie, There is no exact such animation but you can achieve something similar using Hover Box control (via Insert menu): https://answers.themler.io/articles/8397/hover-box Try applying different animation effects and motions in hover box settings. Gina Themler support
plexforce
Thanks for quick anwer, I will give it a try with hoverbox.
