Maximum slide time 10000ms
JEEBEE
JEEBEE posted this 2 weeks ago
So, I've created a slider but I need to extend the time per slide. Why is the maximum slide time 10000 ms? Is there a way to increase this?
Hi, So, I've created a slider but I need to extend the time per slide. Why is the maximum slide time 10000 ms? Is there a way to increase this?
Hello Jorn,
Usually even 10 000 ms is too much for a slider, but if you need to increase it, you can edit js files manually after the theme is exported. This manual edit has to be done every time after the template is updated.
If you need help defining the file to edit, please, attach exported theme and specify what slider you mean.
Hello Jorn, Usually even 10 000 ms is too much for a slider, but if you need to increase it, you can edit js files manually after the theme is exported. This manual edit has to be done every time after the template is updated. If you need help defining the file to edit, please, attach exported theme and specify what slider you mean. Gina Themler Support
JEEBEE
JEEBEE posted this 4 days ago
Please check private section.
