Error with template exporting in Joomla
angelabisesi
angelabisesi posted this 09 August 2019
Hi, i'm trying to to export a template but when i check "Include content" if i look the zip file it's 79kb.
I dont' understand the reason.
I tryed to disable antivirus, tryed diffrent browser using this url (http://127.0.0.1:12080/themler_154385243/startup/).
Can you help me?
Hi, i'm trying to to export a template but when i check "Include content" if i look the zip file it's 79kb. I dont' understand the reason. I tryed to disable antivirus, tryed diffrent browser using this url (http://127.0.0.1:12080/themler_154385243/startup/). Can you help me?
Support Team posted this 09 August 2019
Is the theme exported normally if you don't check "Include content"? Is the issue the same in Chrome/Firefox?
What about a theme copied manually from C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\? Please try to zip-compress it and install it then on your host or where you would like it to be installed.
Hello, Is the theme exported normally if you don't check "Include content"? Is the issue the same in Chrome/Firefox? What about a theme copied manually from C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\? Please try to zip-compress it and install it then on your host or where you would like it to be installed. Sincerely, Nettie
angelabisesi
if I don't check "include content" the template is exported correctly and the size of the zip is about 9.000Kb.
I don't need to copy the theme from its folder because I need the content. I'm tried also Chrome and Firefox.
Angela.
Hello, if I don't check "include content" the template is exported correctly and the size of the zip is about 9.000Kb. I don't need to copy the theme from its folder because I need the content. I'm tried also Chrome and Firefox. Sincerely, Angela.
Support Team posted this 12 August 2019
Angela,
This canonly mean that the content takes the rest of the exported theme size. Could you please upload the theme with the content to some free cloud sharing and share with us?
We can check what part of the content is so heavy.
Angela, This canonly mean that the content takes the rest of the exported theme size. Could you please upload the theme with the content to some free cloud sharing and share with us? We can check what part of the content is so heavy. Gina Themler Support
