Problem with starting
jkolski
jkolski posted this 5 days ago
I've just bought Themler. After installation it runs once correctly. Next time I have blank site, 127.0.0.1_/starting.php. When I am close it several time once runs correctly.
Excludes from antivirus added. After deleting Chromedata first run ok. Next time problem still exists. Result from Themler Diagnostic Tool attached.
Hi I've just bought Themler. After installation it runs once correctly. Next time I have blank site, 127.0.0.1_/starting.php. When I am close it several time once runs correctly. Excludes from antivirus added. After deleting Chromedata first run ok. Next time problem still exists. Result from Themler Diagnostic Tool attached.
9 Comments
Support Team posted this 5 days ago
8. Close Themler and run it anew.
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for any CMS and create a theme. 8. Close Themler and run it anew. Please let us know the result. Sincerely, Nettie
jkolski
jkolski posted this 4 days ago
After reinstallation problem still exists.
Hello After reinstallation problem still exists.
Support Team posted this 3 days ago
It can happen that antivirus or firewall are not disabled completely despite of selecting such option, so could you please try to do the following additionally:
try to add the following whole folders to your firewall white list:
C:\Program Files (x86)\Themler\
Please also add the website *.themler.io to exception list as well as ''themler.com" and "*.billiondigital.com". If it is not possible, please try adding cstatic.billiondigital.com and cstatic.themler.io.
Then please repeat the procedure and let us know if there is any difference.
Hello, It can happen that antivirus or firewall are not disabled completely despite of selecting such option, so could you please try to do the following additionally: try to add the following whole folders to your firewall white list: C:\Program Files (x86)\Themler\ C:\ProgramData\Themler Please also add the website `*.themler.io` to exception list as well as ''themler.com" and "*.billiondigital.com". If it is not possible, please try adding `cstatic.billiondigital.com` and `cstatic.themler.io`. Then please repeat the procedure and let us know if there is any difference. Sincerely, Nettie
jkolski
jkolski posted this 3 days ago
Exception list modified. No change.
Excepion list in attached file
Hello Exception list modified. No change. Excepion list in attached file
Please try to open Themler through a browser using a link like this
http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/
The exact numbers are visible in Themler Live Preview.
Hello, Please try to open Themler through a browser using a link like this http://127.0.0.1:29958/themler_XXXXXXXXXX/startup/ The exact numbers are visible in Themler Live Preview. Sincerely, Nettie
jkolski
Sorry, it does not work with 3 browsers:
Mozilla Firefox
Google Chrome
Microsoft Edge
Hello Sorry, it does not work with 3 browsers: Mozilla Firefox Google Chrome Microsoft Edge
What error message is there in the browser Console?
Also meanwhile please consider working with Themler on some localhost or hosted website. Let us know if you need instructions how to do this.
Hello, What error message is there in the browser Console? Also meanwhile please consider working with Themler on some localhost or hosted website. Let us know if you need instructions how to do this. Sincerely, Nettie
jkolski
Only localhost
Error message see attached file
Hello Only localhost Error message see attached file
Something must be still blocking Themler. Do you have an opportunity to install Themler on a different computer? Preferably under different network.
Themler support
Hello, Something must be still blocking Themler. Do you have an opportunity to install Themler on a different computer? Preferably under different network. Gina Themler support
