css figcaption font-size responsive
Pitter
Pitter posted this 14 August 2019
I have added css format for figcaption font-size in the custom css settings like attachment.
Now I must set the font-size depending on the device i.e. smaller on tablet landscape, more smaller on mobile phone.
Where and how can I do this?
Thanks in advance
Peter
Hi, I have added css format for figcaption font-size in the custom css settings like attachment. Now I must set the font-size depending on the device i.e. smaller on tablet landscape, more smaller on mobile phone. Where and how can I do this? Thanks in advance Peter
Support Team posted this 14 August 2019
Hello Peter,
You can set default fonts under Design -> Fonts -> More Options:
You can also define it in em rather than px to be more responsive.
Hello Peter, You can set default fonts under Design -> Fonts -> More Options: !font-settings.png! You can also define it in **em** rather than **px** to be more responsive. Gina Themler Support
Pitter
Hi Gina,
yes, I know. I specially want to set some font settings for figcaption, because of the used font size is to large (text to long) only for tablet portrait and mobiles.
Can I set this, too?
Peter
Hi Gina, yes, I know. I specially want to set some font settings for **figcaption**, because of the used font size is to large (text to long) only for tablet portrait and mobiles. Can I set this, too? Peter
Support Team posted this 15 August 2019
There is no setting for figcaption in Themler, but you can add custom code to Home -> Settings -> Additional CSS:
@media (max-width: 600px) {
figcaption {
font-size: 1em;
This is just an example. You can add several pieces of this code - each for different max-width. You can check what max-width to specify under Home -> Settings based on your values for different responsive modes.
Themler support
There is no setting for figcaption in Themler, but you can add custom code to Home -> Settings -> Additional CSS: @media (max-width: 600px) { figcaption { font-size: 1em; } } This is just an example. You can add several pieces of this code - each for different max-width. You can check what max-width to specify under Home -> Settings based on your values for different responsive modes. Gina Themler support
Pitter
Pitter posted this 15 August 2019
Thank you, Gina!!
Thank you, Gina!!
