Import Zip Joomla
lesergei
lesergei posted this 10 August 2015
I try to understand why, with "Themler desktop" it is not possible to import a Joomla template made with Artisteer. I know it is possible to export for Wordpress. Pardon the following commentary, but you are working on this program for 3 years, and with Artisteer, it is possible to export for a single CMS!
I just finished a site made with Joomla, and if I want to support the new features offered by Themler, I have to start from scratch for my template, unless I misunderstood.
Hello, I try to understand why, with "Themler desktop" it is not possible to import a Joomla template made with Artisteer. I know it is possible to export for Wordpress. Pardon the following commentary, but you are working on this program for 3 years, and with Artisteer, it is possible to export for a single CMS! I just finished a site made with Joomla, and if I want to support the new features offered by Themler, I have to start from scratch for my template, unless I misunderstood. Thank you
18 Comments
lesergei
Hi again,
I just saw that the last update supports Joomla, maybe I'm too fast! I try to import my template in Themler desktop.
In Artisteer.4.3.0.60818 if I export as Zip Joomla, an error message says "Import fail, only themler themes are supported" and if I export in Zip Themler, an error message tells me "Import fail, joomla themes are only supported"
I am caught in a Mobius strip
Hi again, I just saw that the last update supports Joomla, maybe I'm too fast! I try to import my template in Themler desktop. In Artisteer.4.3.0.60818 if I export as Zip Joomla, an error message says "Import fail, only themler themes are supported" and if I export in Zip Themler, an error message tells me "Import fail, joomla themes are only supported" I am caught in a Mobius strip Thanks
Support Team posted this 10 August 2015
To import Artistere Joomla template into Themler please follow thisi steps:
  1. Download the latest Artisteer 4.3.0.60858 and install
  2. open your joomle Artisteer project in Artisteer and export it as Themler Joomla theme:
    You will achieve a regular Themler theme for Joomla which can be later opened in Themler using Import from ZIP option:
Please let us know if you need our further assistance here.
Hello To import Artistere Joomla template into Themler please follow thisi steps: 1. [Download][1] the latest Artisteer 4.3.0.60858 and install 2. open your joomle Artisteer project in Artisteer and export it as Themler Joomla theme: !joomla-export.png! You will achieve a regular Themler theme for Joomla which can be later opened in Themler using *Import from ZIP* option: !import-theme.png! Please let us know if you need our further assistance here. Thank you, Olivia [1]: http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
lesergei
Thank you, I looked on the site Artisteer, if a new version was available, but had found nothing, and as the program uses the internet to export, I thought that the program would even make it to update.
Hi, Thank you, I looked on the site Artisteer, if a new version was available, but had found nothing, and as the program uses the internet to export, I thought that the program would even make it to update.
We provided a link to download the new Artisteer update with Themler export in each article about supporting Joomla Artisteer themes in Themler and in my previous reply.
Anyway, did you try the new Artisteer update? Does it work for you?
Hello We provided a link to download the new Artisteer update with Themler export in each article about supporting Joomla Artisteer themes in Themler and in my previous reply. Anyway, did you try the new Artisteer update? Does it work for you? Thank you, Olivia
boneal80
boneal80 posted this 13 August 2015
This did not work for me. I created a whole new template with the newest version of Artisteer and still get the message
"Not Found
The requested URL /themler_1329780648/joomla\administrator/index.php was not found on this server."
Yet it does show up when I try to press the back button and I end up back at the Joomla Themler editing portal. I can see the template in the thumbnails, as well as the Recent Themes list when I re start Themler. (I can not get back to Themler itself without closing the tab and re-opening Themler) This is all very frustrating.
This did not work for me. I created a whole new template with the newest version of Artisteer and still get the message "Not Found The requested URL /themler_1329780648/joomla\administrator/index.php was not found on this server." Yet it does show up when I try to press the back button and I end up back at the Joomla Themler editing portal. I can see the template in the thumbnails, as well as the Recent Themes list when I re start Themler. (I can not get back to Themler itself without closing the tab and re-opening Themler) This is all very frustrating.
Support Team posted this 13 August 2015
The problem seems to occur when the template is exported from Artisteer without content. Please use the Include Content checkbox when exporting from Artisteer meanwhile.
Our developers will look into the issue.
Hi, The problem seems to occur when the template is exported from Artisteer without content. Please use the Include Content checkbox when exporting from Artisteer meanwhile. Our developers will look into the issue. Sincerely, Hella BillionDigital Team
lesergei
lesergei posted this 13 August 2015
I installed this morning the empty template with Artisteer exported with the content. When I wanted to edit it, here's what I see. Then once in Themler, this is what happens.
Hello, I installed this morning the empty template with Artisteer exported with the content. When I wanted to edit it, here's what I see. Then once in Themler, this is what happens. Thank you
Support Team posted this 14 August 2015
Hi Serge,
Actually, you just need to run Themler and apply available update.
This should fix the issue.
Ivan
Hi Serge, Actually, you just need to run Themler and apply available update. This should fix the issue. Thanks, Ivan
boneal80
boneal80 posted this 17 August 2015
I AM exporting with content checkbox included. I still get the message "Not Found
After getting this message, when I try to click the back button to try to return to Themler, but it takes me to the joomla template manager warning me that "empty password not allowed and an error saying I am not permitted to use that link to directly access that page". There is absolutely NO way to get back to the Themler interface without just closing out the browser and re-opening Themler!
I give up. Themler is just not worth the headache. I surely hope Artisteer will still be available for those of us who do not want to mess with Themler.
> Hi, > > The problem seems to occur when the template is exported from Artisteer without content. Please use the Include Content checkbox when exporting from Artisteer meanwhile. > Our developers will look into the issue. > > Sincerely, > Hella > BillionDigital Team I AM exporting with content checkbox included. I still get the message "Not Found The requested URL /themler_1329780648/joomla\administrator/index.php was not found on this server." After getting this message, when I try to click the back button to try to return to Themler, but it takes me to the joomla template manager warning me that "empty password not allowed and an error saying I am not permitted to use that link to directly access that page". There is absolutely NO way to get back to the Themler interface without just closing out the browser and re-opening Themler! I give up. Themler is just not worth the headache. I surely hope Artisteer will still be available for those of us who do not want to mess with Themler.
bummm
bummm posted this 17 August 2015
Also problem :(
When included checkbox - just white page and nothing happen, when importing...
Also problem :( When included checkbox - just white page and nothing happen, when importing...
Support Team posted this 18 August 2015
To boneal80: if possible please attach here the zip file with the theme.
To bummm : please enable error reporting in Joomla >> System >> Global Configuration >> Server >> Error Reporting = Development (or Maximum). Then try to install the theme again. In case you get an error post here its full text.
To boneal80: if possible please attach here the zip file with the theme. To bummm : please enable error reporting in Joomla >> System >> Global Configuration >> Server >> Error Reporting = Development (or Maximum). Then try to install the theme again. In case you get an error post here its full text. regards, Aileen
bummm
bummm posted this 21 August 2015
I importing to Themler, not to Joomla.
> To bummm : please enable error reporting in Joomla >> System >> Global Configuration >> Server >> Error Reporting = Development (or Maximum). Then try to install the theme again. In case you get an error post here its full text. > I importing to Themler, not to Joomla.
Support Team posted this 24 August 2015
Please create a new Private topic and attach the problem theme (.zip). Also please follow these steps:
  1. run Themler
  2. press F12 to open Chrome dev tools >> switch to Console tab
  3. reproduce the issue
Do you see the any error (red text) on the Console tab? If so please provide the screenshot of the error message.
Hello > I importing to Themler, not to Joomla. Please create a new Private topic and attach the problem theme (.zip). Also please follow these steps: 1. run Themler 2. press F12 to open Chrome dev tools >> switch to Console tab 3. reproduce the issue Do you see the any error (red text) on the Console tab? If so please provide the screenshot of the error message. Thank you, Olivia
friveraus
friveraus posted this 28 September 2015
Hi Support, I followed the instructions above for importing a Artisteer template to Themler and it did not work. See attached image for the error the popped up.
Felix
Hi Support, I followed the instructions above for importing a Artisteer template to Themler and it did not work. See attached image for the error the popped up. !Error.png! Felix
Support Team posted this 29 September 2015
Hi Felix,
Please attach your theme to this ticket so we can try to help you.
Make sure you're using exactly Themler Joomla export, not simply Joomla export.
Ivan
Hi Felix, Please attach your theme to this ticket so we can try to help you. Make sure you're using exactly **Themler** Joomla export, not simply Joomla export. Thanks, Ivan
jtarano
jtarano posted this 2 weeks ago
I followed the instructions for importing a simple Artisteer template to Themler and it did not work:
"Import Failed only Joomla Themler's themes are supported"
I'm using Artisteer 4.3.0.60858 exporting a simple Joomla template with a minimun content
I followed the instructions for importing a simple Artisteer template to Themler and it did not work: "Import Failed only Joomla Themler's themes are supported" I'm using Artisteer 4.3.0.60858 exporting a simple Joomla template with a minimun content
jtarano
It is ridiculous that this company does not send an acknowledgment of reception the messages that were sent to it and doesn't have a telephone to collect the requests of its clients.
Plus the email published on the web site info@themler.io in the section about us, is rejecting the emails
It is ridiculous that this company does not send an acknowledgment of reception the messages that were sent to it and doesn't have a telephone to collect the requests of its clients. Plus the email published on the web site info@themler.io in the section about us, is rejecting the emails
It is recommended to use https://answers.themler.io/ to contact us, you may also create a private case here.
Please try this Artisteer version:
Make sure to select Export >> Themler and then Joomla in the export dialog.
Hello, It is recommended to use https://answers.themler.io/ to contact us, you may also create a private case here. Please try this Artisteer version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Make sure to select Export >> Themler and then Joomla in the export dialog. Sincerely, Nettie
