can t replacce picture..servor error?
Phil Sanz
Phil Sanz posted this 2 weeks ago
hello, I can't replace images with my template based on themler...Each time I get the following error message: servor unavaliable...I contacted my host but everything is fine on his side...have you had before this kind of problem? the website is www.leshuilesbellechasse.com/administrator
Pass:
Fv4KP=R+71
7Gm(+)6a
go to extension
template
choose: huilesbellechasse1 - par default
and edit template
Last thing if it helps...My host see this message on firefox (in french):
Blocage d’une requête multiorigines (Cross-Origin Request) : la politique « Same Origin » ne
permet pas de consulter la ressource distante située sur
https://generation.themler.io/render. Raison : l’en-tête CORS « Access-Control-Allow-Origin » est manquant.
Thanks for your support.
hello, I can't replace images with my template based on themler...Each time I get the following error message: servor unavaliable...I contacted my host but everything is fine on his side...have you had before this kind of problem? the website is www.leshuilesbellechasse.com/administrator Pass: Fv4KP=R+71 7Gm(+)6a go to extension template choose: huilesbellechasse1 - par default and edit template Last thing if it helps...My host see this message on firefox (in french): Blocage d’une requête multiorigines (Cross-Origin Request) : la politique « Same Origin » ne permet pas de consulter la ressource distante située sur https://generation.themler.io/render. Raison : l’en-tête CORS « Access-Control-Allow-Origin » est manquant. Thanks for your support.
10 Comments
Phil Sanz
https://developer.mozilla.org/fr/docs/Web/HTTP/CORS/Errors/CORSAllowOriginManquant
https://www.chromestatus.com/feature/5629709824032768
https://developer.mozilla.org/fr/docs/Web/HTTP/CORS/Errors/CORSAllowOriginManquant https://www.chromestatus.com/feature/5629709824032768
Please check that Joomla admin panel and front end don't have different domains, encrypted/non-encrypted HTTP connection, etc.
For example, iIf admin panel domain is http://site.com/admin and front end domain is http://shop.site.com/
The admin panel and website front-end domains should match.
The error also may occur if the admin panel and website have different connection encryption, for example:
https://site.com/admin
http://site.com/
Hello, Please check that Joomla admin panel and front end don't have different domains, encrypted/non-encrypted HTTP connection, etc. For example, iIf admin panel domain is http://site.com/admin and front end domain is http://shop.site.com/ The admin panel and website front-end domains should match. The error also may occur if the admin panel and website have different connection encryption, for example: https://site.com/admin http://site.com/ Sincerely, Nettie
Phil Sanz
I checked and everything seems fine on my side.
There is this link that could help if that's not what you're saying:
https://developer.mozilla.org/en-US/docs/Web/HTTP/CORS/Errors/CORSMissingAllowOrigin
Thanks for your support!
Hi, I checked and everything seems fine on my side. There is this link that could help if that's not what you're saying: https://developer.mozilla.org/en-US/docs/Web/HTTP/CORS/Errors/CORSMissingAllowOrigin Thanks for your support!
Phil Sanz
Phil Sanz posted this 6 days ago
HELLO, DID YOU HAVE TIME TO LOOK AT THE PROBLEM?
THANKS FOR YOUR SUPPORT :)
HELLO, DID YOU HAVE TIME TO LOOK AT THE PROBLEM? THANKS FOR YOUR SUPPORT :)
Phil Sanz
Phil Sanz posted this 5 days ago
HI, YOU KNOW I HAVE MANY SITE WITH THEMLER WITH THE SAME CONFIGURATION AND ERERYTHING IS WORKING FINE..MY HOST SAY : IT IS NOT THE SERVER THAT IS BLOCKING BUT THE BROWSER..
CAN YOU HELP ME PLEASE?
HI, YOU KNOW I HAVE MANY SITE WITH THEMLER WITH THE SAME CONFIGURATION AND ERERYTHING IS WORKING FINE..MY HOST SAY : IT IS NOT THE SERVER THAT IS BLOCKING BUT THE BROWSER.. CAN YOU HELP ME PLEASE?
Phil Sanz
Hello, I have something new. in fact the bug is only on the home pages (French / English) on the other pages I can change the pictures so it's not a server or https story....I really think it's a bug on the template level.
Phil Sanz
Phil Sanz posted this 4 days ago
new error...is there anyone at technical support
careygrant521876
careygrant521876 posted this 4 days ago
Everything works on my side. You check the panel. It is the one I use in https://www.assistedonlinefilings.com/.
Everything works on my side. You check the panel. It is the one I use in [https://www.assistedonlinefilings.com/][1]. [1]: https://www.assistedonlinefilings.com/
Phil Sanz
Phil Sanz posted this 3 days ago
Sorry I don't understand...my site is: les huilesbellechasse.com
Pass:
Fv4KP=R+71
7Gm(+)6a
go to extension
template
and edit template
Sorry I don't understand...my site is: les huilesbellechasse.com I can't replace images with my template based on themler...Each time I get the following error message: servor unavaliable...I contacted my host but everything is fine on his side...have you had before this kind of problem? the website is www.leshuilesbellechasse.com/administrator Pass: Fv4KP=R+71 7Gm(+)6a go to extension template choose: huilesbellechasse1 - par default and edit template
Phil Sanz
Phil Sanz posted this yesterday
hi....as I told you before...the bug is in the English and French homepages, the other pages work...so it's obviously a bug in the template...can you please help me
