Hmenu Disappears on Mouse Over
ABSolutions
ABSolutions posted this 09 September 2019
My hmenu is disappearing on mouse over for my Joomla template. See screen shots attached. The site is https://www.respite-now.com.
My hmenu is disappearing on mouse over for my Joomla template. See screen shots attached. The site is https://www.respite-now.com.!Screen-Shot-2019-09-09-at-9.51.25-AM.png!!Screen-Shot-2019-09-09-at-9.51.16-AM.png!
ABSolutions
This is the error I get in development mode :
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home2/clthca/public_html/respitenow/templates/respitenow/functions.php on line 201
It just started doing this on Friday. Hoping to fix it ASAP as this is a live site.
This is the error I get in development mode : Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home2/clthca/public_html/respitenow/templates/respitenow/functions.php on line 201 It just started doing this on Friday. Hoping to fix it ASAP as this is a live site.
Support Team posted this 25 September 2019
Hello Anthony,
I am very sorry for the delay.
1) Your menu works right now, have you already resolved the issue?
2) This warning can be removed if you manually edit the file mentioned in the message and add "2" on line 201. This though can repeat after you edit and re-publish theme in Themler. This warning though doesn't affect any functionality.
Hello Anthony, I am very sorry for the delay. 1) Your menu works right now, have you already resolved the issue? 2) This warning can be removed if you manually edit the file mentioned in the message and add "2" on line 201. This though can repeat after you edit and re-publish theme in Themler. This warning though doesn't affect any functionality. Gina Themler Support
ABSolutions
ABSolutions posted this 25 September 2019
I ended up rebuilding the header to fix the issue.
