Error Server Permission
A12 Web Studio
A12 Web Studio posted this 10 September 2019
I'm using
XAMPP for iMac (Apache 2.4.41, MariaDB 10.4.6, PHP 7.2.22)
Joomla 3.9.11
After MacOS update I can't any longer edit and save Themler theme
I'm very stressed, I've tried any combination even reinstall everything a lot of times but nothing works
I got this error:
the permissions are 777 to all the htdocs folder and subfolder ...
What should I do?
Nancy
Hi, I'm using XAMPP for iMac (Apache 2.4.41, MariaDB 10.4.6, PHP 7.2.22) Joomla 3.9.11 After MacOS update I can't any longer edit and save Themler theme I'm very stressed, I've tried any combination even reinstall everything a lot of times but nothing works I got this error: !Screenshot-2019-09-10-at-16.25.43.png! the permissions are 777 to all the htdocs folder and subfolder ... What should I do? Thanks Nancy
Support Team posted this 10 September 2019
Does the issue persist if you install a new Themler theme in your CMS on localhost?
Hello, Does the issue persist if you install a new Themler theme in your CMS on localhost? Sincerely, Nettie
A12 Web Studio
A12 Web Studio posted this 11 September 2019
Hi Nettie,
yes, the problem persists.
I worked around this problem by deleted manually from the database (and the corresponding folders too) all the themler plugins and all the themler themes and install them again.
I don't know why but this problem happens every time I upgrade my MacOS 🙄
Do you have any clue about that?
Nancy
Hi Nettie, yes, the problem persists. I worked around this problem by deleted manually from the database (and the corresponding folders too) all the themler plugins and all the themler themes and install them again. I don't know why but this problem happens every time I upgrade my MacOS 🙄 Do you have any clue about that? Thanks Nancy
Support Team posted this 11 September 2019
Hello Nancy,
Thanks for letting us know. Looks like every time the system is upgraded, the permissions to some folders or to Xampp in general are changed somehow. Unfortunately, we cannot say exactly.
Hello Nancy, Thanks for letting us know. Looks like every time the system is upgraded, the permissions to some folders or to Xampp in general are changed somehow. Unfortunately, we cannot say exactly. Sincerely, Nettie
