You are not allowed to reach the page
brewer4joke
brewer4joke posted this 10 September 2019
I tried to follow all the solutions reported in this forum in order to solve my problem but I am not able to solve it.
I Unistalled and reinstalled Themler and Dekstop's application seems work.
Later I imported my template in Wordpress and the page confirms me that the template and Themler plugin (both Themler and Themler.core) are rightly installed.
Then I try to tap on Themler in order to edit my template online and appear always the problem reported in the title, "You are not allowed to reach the page".
I tried to open other websites where the plugin worked and now the problem appears in all of them.
I tried to Unistalled the plugin and reinstall, same problem.
I tried to set the proxy so that it can bypass the connection, same problem.
I tried remove all the cache files, same problem...
Edit to add: I tried also to bring the configuration of Chrome, Firefox and Edge to the original settings, same problem
I tried to make the same thing from another point of connection and another PC, same problem.
I really need to find a solution, may you help me?
bye
Hello, I tried to follow all the solutions reported in this forum in order to solve my problem but I am not able to solve it. I Unistalled and reinstalled Themler and Dekstop's application seems work. Later I imported my template in Wordpress and the page confirms me that the template and Themler plugin (both Themler and Themler.core) are rightly installed. Then I try to tap on Themler in order to edit my template online and appear always the problem reported in the title, "You are not allowed to reach the page". I tried to open other websites where the plugin worked and now the problem appears in all of them. I tried to Unistalled the plugin and reinstall, same problem. I tried to set the proxy so that it can bypass the connection, same problem. I tried remove all the cache files, same problem... Edit to add: I tried also to bring the configuration of Chrome, Firefox and Edge to the original settings, same problem I tried to make the same thing from another point of connection and another PC, same problem. I really need to find a solution, may you help me? Thanks bye
Support Team posted this 11 September 2019
You have the issue with Themler on your website at the moment, right? Or in Themler desktop?
Hello, You have the issue with Themler on your website at the moment, right? Or in Themler desktop? Sincerely, Nettie
brewer4joke
brewer4joke posted this 11 September 2019
Thanks for your answer.
The issue is with Themler on all my websites
Bye
Hello, Thanks for your answer. The issue is with Themler on all my websites Thanks Bye
Please make sure that the user and group running on the web server are granted the appropriate read, write and execute (linux only) permissions on the following folders, as well as read and write permission on the files in these folders:
\wp-content\uploads
\wp-content\themes
\wp-content\plugins
Hello, Please make sure that the user and group running on the web server are granted the appropriate read, write and execute (linux only) permissions on the following folders, as well as read and write permission on the files in these folders: \wp-content\uploads \wp-content\themes \wp-content\plugins Sincerely, Nettie
