Kunena menu and Themler bug
frederic11
frederic11 posted this 04 October 2019
i have a problem with Kunena and Themler.
The Kunena menu dos not appear and if i go on a user profile, i have this message :
Notice: Undefined variable: menutype in /home/clients/xxxxxxxx/formation.energie-sante/templates/untitled/html/mod_menu/default_component.php on line 54
Rendering Error in layout Widget/Menu: Call to undefined function funcTagBuilder() in /home/clients/xxxxxxx/formation.energie-sante/components/com_kunena/template/nts_ksamurai/layouts/widget/menu/default.php on line 121
Layout was rendered in /home/clients/xxxx/formation.energie-sante/libraries/kunena/layout/base.php on line 167
I have try with the developers of the NTS Ksamurai theme and with the protostar template all is fine, so it is a Themler bug.
Thanks to help
Hello, i have a problem with Kunena and Themler. The Kunena menu dos not appear and if i go on a user profile, i have this message : Notice: Undefined variable: menutype in /home/clients/xxxxxxxx/formation.energie-sante/templates/untitled/html/mod_menu/default_component.php on line 54 Rendering Error in layout Widget/Menu: Call to undefined function funcTagBuilder() in /home/clients/xxxxxxx/formation.energie-sante/components/com_kunena/template/nts_ksamurai/layouts/widget/menu/default.php on line 121 Layout was rendered in /home/clients/xxxx/formation.energie-sante/libraries/kunena/layout/base.php on line 167 I have try with the developers of the NTS Ksamurai theme and with the protostar template all is fine, so it is a Themler bug. Thanks to help
frederic11
EDIT, i have desactivate the "default_component.php" in the html and it work fine now...
Support Team posted this 07 October 2019
Hello Frederic,
This is reported to the developers.
We apologize for the issue and thank you for letting us know the details.
Hello Frederic, This is reported to the developers. We apologize for the issue and thank you for letting us know the details. Gina Themler Support
