Need to add hyperlink to a container/div
frank38
frank38 posted this 05 October 2019
I know the app doesn't let you add a class to containers except for Sections. But I need to add a link to a whole container. I'm not a programmer so I could use some help with this.
I think the class name is:
data-control-id-1639017 or bd-layoutbox-48
or both???
Can't figure what the javascript should be... using this:
<script>
$(".bd-layoutbox-48").click(function() {
  window.location = $(this).find("a").attr("href");
  return false;
</script>
**html example:**
<div class="bd-layoutbox-48">
  blah blah blah.
  <a href="http://google.com">link</a>
</div>
I know the app doesn't let you add a class to containers except for Sections. But I need to add a link to a whole container. I'm not a programmer so I could use some help with this. **I think the class name is:** data-control-id-1639017 or bd-layoutbox-48 or both??? **Can't figure what the javascript should be... using this:** <script> $(".bd-layoutbox-48").click(function() { window.location = $(this).find("a").attr("href"); return false; }); </script> **html example:** <div class="bd-layoutbox-48"> blah blah blah. <a href="http://google.com">link</a> </div>
Support Team posted this 07 October 2019
Hello Frank,
Classes that start with "bd-" are from Bootstrap, they are in most cases dynamic and may change with every page reload.
In your case I would recommend adding custom HTML (via Insert -> HTML), to the beginning of the container content and add unique class to that HTML control instead.
Hello Frank, Classes that start with "bd-" are from Bootstrap, they are in most cases dynamic and may change with every page reload. In your case I would recommend adding custom HTML (via Insert -> HTML), to the beginning of the container content and add unique class to that HTML control instead. Gina Themler Support
