Floatting WhatsApp button
danielc.eco
danielc.eco posted this 15 October 2019
I want to know how can I make a floatting WhatsApp button.
Thanks.
Daniel
Hi, I want to know how can I make a floatting WhatsApp button. Thanks. Daniel
Support Team posted this 16 October 2019
Hello Daniel,
Themler doesn't have build-in integration for WhatsApp, but you can add HTML control somewhere in the content or footer area in Themler and then use 3rd party solutions for WhatsApp. For example: https://codepen.io/demoonkevin/pen/MvPEpV
HTML code is to be added inside HTML control box (the box can be added via Insert -> HTML menu).
CSS is to be added in Themler -> Home -> Settings -> Additional CSS.
Please, note that we can't tell which 3rd party solution will definitely work, it is up to the users to try and test.
Hello Daniel, Themler doesn't have build-in integration for WhatsApp, but you can add HTML control somewhere in the content or footer area in Themler and then use 3rd party solutions for WhatsApp. For example: https://codepen.io/demoonkevin/pen/MvPEpV HTML code is to be added inside HTML control box (the box can be added via Insert -> HTML menu). CSS is to be added in Themler -> Home -> Settings -> Additional CSS. Please, note that we can't tell which 3rd party solution will definitely work, it is up to the users to try and test. Gina Themler Support
luciham20
luciham20 posted this 4 weeks ago
That's a very good post, This post give truly quality information, I'm definitely going to look into it, Really very useful tips are provided here, Thanks for sharing. alto's odyssey
That's a very good post, This post give truly quality information, I'm definitely going to look into it, Really very useful tips are provided here, Thanks for sharing. [alto's odyssey][1] [1]: http://altosodyssey.io/
danielc.eco
danielc.eco posted this 4 weeks ago
Hi Gina
The code that you have sended doesn´t work. I'm sending you print screen error.
Tnks
Daniel
Hi Gina The code that you have sended doesn´t work. I'm sending you print screen error. Tnks Daniel
